Changing the chinese voice of TPA3110 Sanwu Bluetooth Amplifier Board SW-HF47
In principle you can, by getting an eprom programmer, and hacking the bluetooth chip. Saying that this is a profoundly non trivial undertaking doesn't even touch the sides. The best way to fix this problem is to buy another board.
Not very diy, sure, but there comes a point where you have to do a sanity check.
No, I was more thinking about ordering some from Sanwu without the horrible audio notifications. Sanwu's website claims:
"Customization is available for order >100 pcs:
1. Customs bluetooth device name
2. Customs audio notifications / Remove audio notification"
Is there a big enough interest for this ?
The BT chip has no markings? If it's anything like the other BT chips, it should have some utilities to configure the things you're asking and/or AT commands via TTL serial.
Maybe you can poke around and see which pins outputs like 3.3V?
I looked at some other pics and I see JL marking Not Found
Hello everybody,
the bluetooth chip on those amps is marked JL and it's a Zhuhai Jie Li AC4602 (datasheet http://img003.hc360.cn/m8/M05/24/ED/wKhQplXIRpOEYX7NAAAAAFTCggE353.pdf)
I even found an SDK for it ( https://pan.baidu.com/s/1gd4RcOj?fid=793451425422902) that can be used to compile the C++ programs and flash them to the chip.
The chip can be accessed via USB, soldering a cable to the 4 exposed pads on the bottom face of the board (just under the JL chip).
There's another thread talking about this
http://www.diyaudio.com/forums/class-d/301607-tpa3110-bluetooth-boards-ebay-2.html#post5474656
Hey Lormat,
thanks for the data sheet,.. at least it gives a little insight in the spec of the chip
did you get anywhere with the SDK?
ATM I can't even get on to that web site,.. I'll keep trying, but it's be useful to know if there's any point
Hello everybody,
the bluetooth chip on those amps is marked JL and it's a Zhuhai Jie Li AC4602 (datasheet )
New tpa3110 Bluetooth boards on eBay - Page 2 - diyAudio
Boa tarde meu amigo, você conseguiu usar o SDK, o qual você deixou o link para download?
:cop: This is an English language forum, please post in English or provide a translation of the post if you can't.
Good afternoon my friend, were you able to use the SDK which you left the download link for?
