100W Ultimate Fidelity Amplifier
Here is the list of change,
Bc546/556 for bc547/557
A1220/c2690 for 340/350
Mje15034/15035 for 1837/4793
Mjl3281/1302 for 1943/5200
Offset is on the high side, actually one channel is around 6mv another is 17mv, but no problem so far, no hiss or hum.
For the sound, high is very good comparable to class A amp, bass is not as deep as I would like it to be. I will change the main filter cap and see what happen. Now I'm using panasonic I plan to change to Nippon chemical.
C.S.
Thank you for sharing your experience with us :)
Sha
Plz see this
Hi guys plz see this .It's OK or not
Sunny22g,
First, you have to change fuses with smaller type 5X20mm , missing input capacitor and ground lift resistor, don't forget to link A points with wire under PCB . Cut PCB at normal size, make some hols in corners . Pcb was tested and it's functional .....
Regards Alex
Sunny22g,
Regards Alex
Alex it's been a long time, i hope everything is fine with you.
Do you have an extra AX40 pcb to sale?
Junie
