Big narrow sub under the bed
This was the rough box layout for the one I had in mind for under my sofa saving material and footprint by combining walls of two enclosure sand ports.
Thanks graham, that's a fine looking sub.
However your last drawing is basically two subs with double volume? Or am I missing something here..
I am still learning modeling software and so far it only pre-calculates tke length or diameter of the vent, so I have to learn to specify both parameters and see what I get. Is there another way to do that by changing box parameters?
Also, I understand that a standard port inverts a phase of sound wave, so in result you get a half-period delayed wave summed with actual wave, so the sound should be not as "accurate". But you probably don't need "accurate" at 30Hz.
What a very large vent does I have no idea. Probably same thing as adding insane weights on to passive radiator, which lowers overall Fs? Reading continues...
Bought myself a single Reckhorn D-165 and a couple of passive radiators. Just because it's so cheap and close by (also cheap delivery).
Their prices are so damn good. Also took a car speaker set to replace my awful tinny-muddy WRX speakers.
Also could not resist on the body transducer:
shop.reckhorn.net - BS-200 Body shaker for home, car audio, games and therapy
I don't expect much, but I have never played with these before. I wonder if it could be attached in a car somewhere to add some lows. They say it can be mounted under the seat, but I could not find any public builds.
I haven't done it before, but in theory, I'd go with these ideas combined:
My two 6.5s are in sealed 0.5 QTC boxes and with room gain get fairly low.
BTW, sub-painting on a wall.. Has been done before
...assuming you can hang the speaker directly behind the listening position.
Each halving of distance is ~6dB of gain, so a sub that is 25cm from your head rather than 100cm from your head will subjectively have about 12dB of 'boost'. That's a big deal. It will also be 12dB less loud for your neighbors.
A ~12 dB proximity boost is much larger than the boost you'll get from choosing one (small) enclosure over another.
Yeah, close proximity is a worthy goal in most HIFI/HT apps, but few even consider it even though digital TD is available on most consumer receivers nowadays and available for cheap on outboard software, signal processors, etc..
GM
