Looking to avoid ground loop problems by using a pair of class II/double insulated power supplies to give +20-0-20v rails for powering a class AB TDA7293 https://www.st.com/resource/en/datasheet/tda7293.pdf
The amp module is this one TDA7293 Digital Audio Amplifier Single Channel AMP Board AC 12V 32V 100W-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
Ground loops are one problem, ClassII switching supplies generating substantial common mode noise another.
I recommend single PE-grounding of the secondary circuitry.
btw - there is really nothing "digital" on that TDA7293 pcb - just marketing blurb.
Ok I had a look through my junk pile and found 2 double insulated plugpacks that have mains frequency transformers with AC outputs. however they have different voltages. One is 12V AC and the other is 16V AC. I could rectify and smooth these.
Aside from the asymmetric clipping behaviour would the differing rail voltages produce any other side effects?
I did NOT exclude switchmode powersupplies - I use them with my guitar amps as well. But the secondary side should be grounded anyway.
Obviously you must ground the amplifier chassis, whether using computer power supplies or the correct power supply, to make it safe for use.
I though the whole point of 'class II/double insulated' was to remove the need for a mains protective earth connection. Class II plugpack power supplies usually have no earth pin. If an earth pin is present, it isn't connected to the secondary.
Why does the secondary need to be grounded when using a class II/double insulated power supply?
The grounding isn't really for safety its for providing a path for the aforementioned common-mode noise to return to source.
Isn't that normally provided by a class Y capacitor inside the power supply as explained here
switch mode power supply - What does the Y capacitor in a SMPS do? - Electrical Engineering Stack Exchange
- Power Supplies
- Are class II switch mode laptop power supplies OK for audio amps?
