How to measure impedance of 3 way speaker
I put together a pair of 3 way speakers from left over parts. Xsim told me the system impedance would be mostly 8 ohms but the DC resistance of the system measures 11 ohms. Is there a way to measure the actual impedance of the system? I have a DATS V2. All the drivers are rated at 8 ohms.
REW (Roome EQ Wizard) has a section that outlines how to make impedance measurements. Its been a while but it boils down to a box with a resistor connected to your speaker, run a sweep and you'll get an impedance plot.
DATS is not just for Thiele & Small Parameters.
It can used to measure loudspeaker impedances too.
Below is an impedance sweep of my 2-way.
