Here is the best way to go into A2 territory:
Do you sell fully completed?
Hi Andy
Have you tested it on the 01a as well ? Would be interested in your findings compared to gyrator. Thks
I did a very rough-and-ready comparison of some plate chokes today, using 3 tracks from opera, orchestral and popular vocal. The Lundahl and Hammond are interstages so just used the primaries. My first observation is that they were all satisfactory and pretty close in sound quality. Preamp was 2P29L running at 13mA. My tentative rank order was:
1. NP amorphous core 136H, 15mA - sweetest treble, smoothest
2. 2 x Hammond 126C in series, 212H, 15mA - clearest, most detail
3. No-name ?Chinese choke 50H ?40mA - clear and quite smooth
4. Lundahl LL1660/18mA - clear and quite smooth
I have less than an hour on my larger NP plate choke, so needs more burn in but already I can tell it's clean and detailed.
Conclusions? Amorphous was the sweetest sound here, but I don't have frequency or distortion testing equipment so I'm afraid this is listening only, and as said, results were close and all were satisfactory. I hope to do some testing against Ale's gyrator in the coming weeks.
Sure, I can. I can order more boards and sell as kits, or boards only, or complete soldered boards. But I am a design engineer, not a soldering pro, so may be you can do it better.
The board also contains an anode load resistor for the previous stage and a coupling cap, I am not sure which values would you like.
If there is an interest, I can run some production for a group DIY. In my Gubernator-71 thanks to such a driver I am getting 45W per channel. I plan also to use this boards for hybrid phone amps, as an output stage.
Do you use FET source follower?
Without this, the 01a -even if it's gyrator loaded- output impedance - usualy - not enough low for proper driving AVC/TVC.
It modeled fine in LTSpice, Gap has been fine tuned as well. At unity gain, output impedance is about 600 ohm. I can post the plots tommorrow if you want to take a look.
I'm in
Ok, I will post in a "wendor bazaar" as soon as ready!
PM me please so I will remember who asked.
I would also be interested in that. The gyrator has too much gain for my system (power amp is 250W @ 1V input! 😱)Hi Andy
Thks
Here's a plot, choke loaded with various capsDo you use FET source follower?
Dear deafbykhorns,
I am interested with intact autoformer too.
Can you share your experience and post photos on your set-up?
New AVC
Just connected the new AVC on the output. All i can say is, wow!
Took this preamp to new levels. I can definitely hear a distinct difference between a resitive input volume control and an AVC volume on the output. The 01a has plenty of current to drive the AVC despite the concerns. With volume around 50%, output impedance is around 600ohms which drives cables and following preamp beautifully. I’ll run some sweeps in the following weeks along with my new/old HP8903 i picked up last month. Think of an AVC like a step down IT transformer driving grid current on a transmitting tube. I think my GM70 amps like to see this impedance.
See post 291 for some interior pics prior to the AVC
Can you post the latest schematic? As far as I remember you are using Ale's gyrator but there are so many diverse (and very useful) posts happening that I've temporarily lost track.
I don't have a complete schematic except for some simulations I did in LTSpice per attached.
Design is simple, tube rectifier to choke loaded power supply to a voltage regulator, coleman supplies, filament bias, plate choke.
Chassis has a divider with ultra perm mu metal to provide additional shielding.
Also using a soft start delay for warm up, I also use an octal to 4pin adapter to try different rectifiers like the 83.
The preamp is dead quiet
Im curious too, are you not loosing bass, snap etc during playback ? For light music you might not hear it but with complex music, you will hear it like some diffusion etc.
Absolutely not! It was somewhat with a resistive input volume control but not with the AVC. I have thrown just about every genre at this preamp and it performs beautifully. I was using an Audio Research SP6 prior to building this pre-amp. I expected a subtle difference, however in the first 5 seconds it was obvious this preamp is much better than the SP6. Not sure if its the Z or a combination of the 01A DHT and the AVC.
Remind me what plate choke you are using? Is this one of Dave Slagles as well? Plate chokes are my personal choice, and as I was saying earlier in the thread I'm really liking the amorphous core ones from NP Acoustics in Vietnam. I think this is a good place for amorphous. Some prefer other choices for the OPT.
Khmmm....it is no coincidence, that more people -I'm too- are sceptical...Absolutely not!
This choke loaded 01a output impedance about 5k (before coupling capacitor).
It's greater, -at least one order of magnitude- than optimal for AVC.
- Tubes / Valves
- 01A question
