Why did you swap the driver board to the other amp instead of repairing the driver board that was originally in the amp?
the other amp driver board was missing.i did know the card was blowing the mosfets .because the same ting happened to the other amp.never encountered this problem before .have you?
I have not. If you get it working again, check the oscillation frequency at the input of the output filter inductors.
what on this board causes the amp to go into protect mode??I have not. If you get it working again, check the oscillation frequency at the input of the output filter inductors.
I have new modul, my location jakarta indonesia 🙏the other amp driver board was missing.i did know the card was blowing the mosfets .because the same ting happened to the other amp.never encountered this problem before .have you?
- General Interest
- Car Audio
- hifonics drive board
