Aleph P 1.7 Volumecontrol Output-imendance question
don't put the attenuator before the aleph. that will result in a noisy preamp. there is a reason that it is behind🙂
In pass B1 buffer preamp and in majority of cases we have the attenuator before the preamp and then followed by the main power amp.
(ie. source ---> attenuator ---> preamp --->power amp)
What is the reason for having volume control / attenuator after the preamp here?
(ie. source ---> preamp ---> attenuator ---> power amp)
Here is the schematic of the output shunt resistor network.
Hi mr. Pass
Thanks for the schematic of the attenuator ..
Could you please give some info regarding its placement , ie. Between the source and preamp or between preamp and power amp .. or it doesn't matter in either case ?
On b1 the volume potentiometer is between source and preamp buffer and in aleph preamp it's between the preamp and power amp ..
Just wanted to understand what is the reason for putting the attenuator at the end of the preamp instead of at the beginning of the preamp as we more often see, for example in pass b1 preamp .. could you please give some info regarding this ..
I think Papa just wanted to take advantage of Aleph P being able to drive any load so he stuck a 1kOhm attenuator behind it, so any noise contributed by the preamp itself also gets attenuated (a purist approach I guess). since that brings the output impedance up shorter leads (up to 3 feet) to the following amp stage are recommended.
Aleph P itself does not like a hot input and there are attenuating resistors with dip switch settings at the input to drop the level if necessary.
...what is the reason for putting the attenuator at the end of the preamp instead of at the beginning of the preamp as we more often see....
From the now-secret Service Manual:
The volume control system ... ... to achieve good common mode rejection performance, the output attenuation must be matched far more precisely than can be accomplished with potentiometers, and so relays and precision resistors are used.
Yes, this is "different". Mr Pass is known for re-thinking conventional methods. We normally pot first then line-amp, so we won't overload the line-amp.
Pass was working with BIG devices at high voltage. Overload won't happen.
These devices "may" have more hiss than conventional designs (I am not an expert on this). Pot first puts turned-down signals close to hiss. Bringing signal in un-reduced gives best signal/hiss ratio.
We don't normally pot after the line amp (though I know a few which pot before and after, much $$$). With conventional line amps this is a waste of line-amp output, and also messes with the impedance at a point which may be driving long cables. But again Pass was working with BIG devices idling at high power, and these conventional trade-offs were re-thought.
It looks fine to me. Not the thriftiest music-box around, but sometimes that is not the point, the music is.
Worth noting, there were additional gain controls via pots between the
Sources of the Mosfets, degenerating the gain, and were used as balance
controls. In spite of better numbers with maximum degeneration, most
users preferred a high gain setting, even if it meant running the output
volume control low.
