2n3904 pre amplifier improvement
Moderator
Joined 2011
Then I should go for opamp.
I have my own preamp with bc547 but it is too complex to explain to a 9year old boy.
The op amp is good. You can use a plug-in socket with it in case of damage.
There are plenty of pcbs ready to hook up or build, on ebay.
It's best to use a 9V battery for the preamp, instead of a line operated supply, for safety.
Here is a schematic for using TL061 with a 9 Volt battery.
I use TL061 because it draws very little current.
This makes the battery last longer.
The voltage gain is like 4. (R4/R3 + 1)
The circuit will work the same with TL071.
