With no switch, the setting it going to be the 'low' option. No jumpers needed.
Sweet ok cool, so will just leave that switch off
Thank you
For the 3 position switch EG2319 seems to be a suitable replacement
For the 2 position switch EG2219 seems to be a suitable replacement
EG2319 E-Switch | Mouser
EG2219 E-Switch | Mouser
I ordered some just to have a look and the pin outs are all correct but the actuator is slightly to short, it is 9mm and I think the amp probably needs about 12mm
I'll post these back to Mouser for now, thank you for the help though
I have used these switches on all of the slash series amplifiers that have needed replacements. I've also used them on some of the "e" series and "HD" series JL amps. That's for the EG part numbers I listed above.
The 9mm are definitely too short at least for the XD1000 5v2 model, I am fairly certain now that it is these two switches which are needed for anyone looking to replace the same ones in the future
SK-22H04-G 12 NS and SK-23D04-G 12
https://www.ckswitches.com/media/1432/sk.pdf
Just also wanted to say thanks to everyone for the help, have just bridged connections for now till the switches arrive from Motronix
- General Interest
- Car Audio
- jl audio XD1000/5v2 identify slide switches for replacement
