JBL JRX 112 crossover
Here is the 2WAY schematic of the JBL JRX 112 can anyone explain the exact use of the specific capacitors clearly marked with red arrows Bipolar of 8uf ?
The 8uF ( in the HF leg ) forms part of a low-Q, 2800hz notch.
The 8uF ( found in the LF leg ) is part of a high-Q, 965hz notch.
I wouldn't disable these notchs since they actually are shaping the overall response.
If they are blowing up it's because the voltage rating must be under-speced for the sort of duty you're putting them through.
Replace these ( BiPolars ) with Mylar film ( or Polypropylene ) capacitors rated for 400V.
684983d1528128290-jbl-jrx-112-crossover-jrx-jpg
Michael ...good to see you after such a long time !!! Hope you are doing fine
Earlk thanks for the detailed explanations
Correct the quality of parts there creates problems most of the time cross point choice there is a bit overestimated next to the driver and teh sound of those was never something realy nice
One way or another the circuit is now changed in the 212 series and cross point is altered any way
Thanks for your help my friends !
