6CD6 triode curves
About 800 ohm, based on Nakabayashi spice model for 6CD6 in triode mode.
Here are some triode curves for the 6EX6, which was a lightly upgraded 6CD6 (ratings). Should be nearly the same curves. (6CD6 Mu 3.9 at 75 mA, 6EX6 Mu 4.2 at 67 mA)
50mA/div Vert., 50 V/div Horiz., -6V grid steps
Thanks. I'm thinking of building an amp with these tubes but using those VPT series PTs I'm always raving about. I'm hoping to use a B+ of about 160V and fixed bias or one of Pavel's audipamp.eu solutions. I'm hoping to run a pair with about 1k2 Raa. The actual goal is 1W class A and the rest B.
That would be 300 Ohms per tube in class B and 600 Ohms per tube in class A.
Seems rather low for an 800 Ohm Ri triode.
7867 appears to be a similar tube to 6CD6/6EX6 too.
6KV6 (22 Watt) also similar tube. (6KV6 = 6KM6 with added grid 1 cooler fin)
That would be 300 Ohms per tube... Seems rather low for an 800 Ohm Ri triode. ...
Rp is more like 425r at the zero bias line, where it will clip.
Still agree that 300r load on a 425r tube is "bad engineering". Bigger fatter tubes, or wound-up transformers, are not that expensive.
But clearly he is not aiming at a dam-buster. More like an odd-parts project.
Yeah, it "works". You can even make the 28V drive with a triode on the same power supply. Looks like 8 Watts max output. May have to nudge the 15W Pdiss to make a Whole Watt still in A. (Notice >30W of big heaters!! A 6V6 at ~300V can make more audio out than its heater demands.) (Note that running Pentode at ~200V with same load offers ~~30W output.)
Good to know. Right now I'm running 6N13S PP both halves in parallel into ~600Raa and I like it. I'm not opposed to running pentode mode though. Looks like 2k4 would be better unless I want to parallel tubes. When you say "bigger, fatter tubes" do you suggest something like a (3)6LW6? Also I assume that 30W pentode mode figure is at ~1k2 Raa?
