Aleph J variant with N-channel JFETs?
Is there an already baked schematic of an Aleph J with N-channel JFETs on the input?
I have bought some 2SK170 parts on speculation and they appear to be genuine with some good matches. So far, no luck fining genuine 2SJ74 on spec that are genuine and are resonably priced.
I am matching for Idss and gain around the 5mA bias point.
for line level duty , which is the case here , I don't care for noise difference between Toshiba JFets and J271
no direct complement , though I have bunch of J309 with bunch of J271
one day I'll maybe make something of them , together
Thanks. I will order some of the SOT23 version of the J271 and see how they measure and how they work in circuit. You are correct that the SOT version is much less cost than the TO92 version. More important, they are actually in production and available.
The SOT23 version datasheet is very quiet about noise. The TO92 datasheet says that noise is maybe 10X of the Toshiba part. As of today, I do not have a way to measure the noise. That is on the list to acquire or build.
Hi Dennis,
Thanks. I did see Patricks amplifier and I'm sure it's a great amplifer.
However, I was just toying with the idea of an mirrored Aleph and not using the IRFP9240 since the Harris parts is not available.
Mogens
Hi Zen,
Yes, I'm sure you are right. Also, a nice amplifier.
Btw. Living in the northern part of Denmark enabled me as child to see a lot of swedish tv for children. It was the best. Pippi and also Emil.
Mogens
I told ya it's easypeasy
:clown:
