ready made enclosure for convenience
I am looking for an aluminum enclosure for the ES9038Q2M board. Any opinion on this case from minishow0328?
MINI aluminum chassis case for ES9038Q2M DAC DSD Decoder | eBay
It doesn't show the back so it is not clear if it has the proper cutouts for all the connectors. Also, where would you put the power supply? Doesn't look like any extra room in the case. Are you are thinking of using a single-ended wall-wart or something?
Also, those DAC boards without any electronics mods don't sound all that good. That is why many people are interested in modding them. Putting one in a case that costs more than the board could end up looking a lot better than it sounds.
IIRC I have seen this case to be offered with this very board and wall-wart PS on eB somewhere so the chance it will have the right cutouts on the back panel is not bad. In my opinion the points Markw4 mentioned are valid. I myself use to proceed in decision process in following order: basic kit > desired functions > other boards/PS > space needed > case optics >case selection. Sometimes I make compromises if I find a really appealing enclosure though ;-). I depends on your possibilities to modify the panel, cutouts, galvanize etc. or if a bench drill is the only tool you have at hand...
Minishow sent me these pictures which seem to be ok and the case function is what I am looking for:
Minishow also said that the back panel is pre-drilled for the ES9038Q2M board. I am looking for first hand experience with this or other case.
Ha Ha same could be said of some commercially available high End DACs. Of course the Benchmark is an exception since the case does not look so hot.
Depends on where you want to take this board. Markw4 is seriously modding to a very high standard. You could do some mods that might fit in there but will not reach the level as markw4 is shooting for.Minishow sent me these pictures which seem to be ok and the case function is what I am looking for:
Just make sure that what YOU want to END up with will fit. I would say assemble everything as close to the final sould you want, live with it a few weeks and IF it is indeed final then time to find a case. As for myself. What i thought was final a couple weeks ago has been shelved and I might end up looking for a case perhaps twice as large as I had initially thought I needed.
I decided to use up as many transformers as I could use from my collection as well as all the High Quality Linear supplies I have lying around and throw all the parts bin into this project. Because it is possibly my last "build". Does that ever happen?
I am talking about the Q2M instead of the PRO chip. I am looking for a modern DAC at budget price. I have toroidal transformer and regulator dual voltage PS left over from my headphone project. This DAC will interface the Blu-Ray player (Sony BDP-S7200) and the cable box to the analogue preamp.
The Minishow case is priced right. If the enclosure quality is good, it allows me to get the DAC up and running in a quick weekend project. My reference point is the Topping D50 or SMSL M8A at half the price, and a higher quality power supply. Any reason not to?
Just a day ago I have finished the setup (however, very simple setup) with exactly this board. For my ears, sound is good. So, if you have any question, please, let me know - I will answer whatever I will be able.
BTW, probably, there is the sense to create another thread regarding to this board?
Yes, please do. We are all looking for hidden gems and ways to polish them!
Any reason not to?
The Q2M can perform very nearly as well as the PRO chip. Distortion for Q2M if very carefully implemented can reach -120dB. For PRO with careful implementation, distortion can be as low as -122dB.
What is mostly different between Q2M and PRO is best obtainable noise performance and versatility.
Without serious mods, I forget exactly what it is for voltage mode operation with this board but distortion might be around -70dB or so. Not very good. Not even good enough for good 16-bit playback if one considers that 16-bits goes all they way down to -96dB.
All in IMHO, of course.
Markw4, in your opinion, the commercial ES9038Q2M board is a terrible implementation? It is useless without "serious mods"? Your view seems to contradict most of the reviews of this board.
-70dB distortion is 0.03% in distrotion. While not superlative, it does not seem too bad to me in analogue term. Does the board really have 0.03% distortion? How audible it is? I need to come up to speed on DAC specification!!
What constitute "serious mods" by your view? I am looking for a modern DAC that can be built at budget price. What board will be better than the ES9038Q2M?
I'd love to see a source for -70dB. The older ESS chips are specified at -108dB in voltage mode, although I would accept this is the absolute best case.
I had posted this earlier but posting it again
Measurements Of Generic ES9038Q2M DAC Board | Audio Science Review (ASR) Forum
These measurements correlate with JensH measurements
Even with the change to the output stage (Current mode) the distortions persist albeit at lower levels (See JensH second set of tests)
I tested these boards too recently and found that my unbalanced I/V measurements correlated with JensH
However the question remains. What could be causing these distortions. Random jitter will raise the noise floor. Correlated jitter will usually create 2nd harmonics and the jitter test in ASR seems to negate any jitter
I plan to measure the raw output sometime soon
Cheers
Cheers
Actually, percent THD is a fairly meaningless number in the sense that it does not correlate with human perception almost at all. For harmonic distortion it really depends on which harmonics are present and in what amount. Very low order harmonics, primarily the 2nd and 3rd are much less objectionable than higher orders. 2nd harmonic can be hard to hear (for an untrained listener) sometimes at a few or several percent. On the other hand, higher order harmonics can be quite objectionable at .01%, IIRC. Earl Geddes did quite a bit of research in this area and he says THD at a performance metric is completely useless.
For DACs there are other types of linear distortion (most objectionably, group delay) and types of distortion and ugly sounding non-random noise such as can result from timing jitter. A comprehensive set of measurments is really needed to fully evaluate a DAC from the technical perspective.
The reference DAC here that I am using is a Benchmark DAC-3 which was reviewed by Stereophile. Their measurements can be seen here as one example: Benchmark DAC3 HGC D/A preamplifier-headphone amplifier Measurements | Stereophile.com The DAC3-HGC they reviewed retails for about $2.2k.
The Chinese DAC we are working on here probably costs a bit over $200 to fully mod (includng the cost of the DAC board itself), that we know of so far (and we are very near the end of the project). That is a budget price compared to what you would have to pay for that level of sound quality commercially. Probably up around $1k or maybe more. Thing is as price goes up, manufacturers tend to add bells and whistles rather than put all the money into sound quality. (Benchmark is an exception. They make a plain box with a lot of very well engineered circuitry inside primarily aimed at sound quality above all else. But they mostly sell to professional recording and mastering studios, movie soundscore editing, etc., and somewhat to audiophiles. So, they have a different business model than most.)
The low-cost Chineses DAC manufacturers also have a business model. They try to figure out what will sell in the rock bottom price range aimed at people looking for a bargain and thinking they can get something cheap, self-customized, good, etc., based on use of a few brand name parts and the rest mostly cheap parts made to look similar to good parts, and using the cheapest low-cost circuits imagniable. So what? Unfortunately, it just so happens that with DACs that the brand name of the chip is much less important than the implementation, the quality of the circuit that the DAC chip is put into, and including the quality of all the other parts in the circuit. That's why we have to mod to get pretty good sound quality if we start with the DAC we have.
DACs are very sensitive to clock quality. cdgames who makes the Allo DACs has said the same things I do, BTW.
The clock that comes with this DAC is what is known is the trade as a standard crystal clock. Such clocks are specified for jitter performance down to about 12kHz.
DACs are highly sensitive to jitter far below 12kHz. Good DACs use clocks known in the trade as ultra-low jitter. They are specified for jitter down at 10Hz or maybe even 1Hz. There are a variety of clocks that could be used for this DAC but to play back at the highest sample rates it supports requires 100MHz. There are some Japanese clocks that are very low jitter but they are only available up to 50MHz. In reels of 3,000 they only cost maybe $2 each. One or two at a time, if you can find them, probably go for $15 or so depending on the seller, shipping costs, etc. Good 100Mhz clocks are available for under $30. No surprise they don't come included with $39 DACs where the DAC chip itself costs $15.
Oh.. I totally agree with you regarding the harmonics present. I have said this too several times in the past. In fact in phase second harmonics great for my magnepans. I deliberately introduce them in my preamp using a low biased jfet. For me thus the source has to be clean or I have to bypass my preamp
The question however is what is causing these harmonics to be present in such high numbers. The ASR tests are pretty decent and it gives me no clue as to what it would be. I understand the clock has to be clean but a bad clock would show up in the J test. Maybe the ASR test is flawed?
I also agree with you that after a certain point mods are not worth it.
I ll wait for the other board that I ordered with the sync SA receiver. Hopefully that one is worth it out of the box
I put a Chrystek 575 clock in my Chinese DAC and sure enough, it made as big a difference as any of the other big differences, such as going from voltage to current modes, regulating AVCC as ESS recommends, getting the analog circuits off the digital power, etc.
Actually, there are not a lot of mods it is just a lot of work to do them.
They are:
Use IV output stages with differential summing
Clean up all power issues, including AVCC as ESS recommends
Use ultra-low jitter clock
Use minimum-phase slow-transition reconstruction filter to minimise audible group delay
Upsample to move reconstruction filter transition band out of the audio band
Only 5 mods, they all make an audible difference, and they all make sense that they should help.
I am working on getting ready to test one last possible mod which is 'master mode I2S,' for want of a better name. The DAC chip will be I2S clock master which means it should be possible to turn off ASRC in the DAC without penalty. In fact, cdgames says it sounds better and the Allo Katana DAC will use that mode. I will see if I can reproduce his results with my DAC and if so I will try to make available a mod anyone can do, and do so in a way that is compliant with the ESS non-disclosure agreement.
They are:
For all these assertions about clock sensitivity, it doesn't align with the JTest result on a stock board shown earlier (measured with a QA400). It's midway down: Measurements Of Generic ES9038Q2M DAC Board | Audio Science Review (ASR) Forum
His claimed mods were to use a bench PSU for the +/- 15 V and an XMOS usb to i2s board. Fast roll off linear filter.
The sidelobes were -120 dB intermodulations with 60 Hz. No other spray. Sure, one can do another 20 dB better with careful effort of the layout and better power isolation, but we're not showing a defective clock here. There's no spray of harmonics anywhere. Clean clean clean, which is good because ESS advertises this very fact!
Which certainly leaves me scratching my head about this mod.
Clock jitter rises rapidly as frequency goes down, much like 1/f noise. It can look pretty good at 100Hz and much worse at 10Hz or 1Hz.
It is known that human attention tends to be attracted to very LF sound variations. People have speculated as to why, and why humans might not like it in DACs. But, who knows?
For whatever the reason, clocks specified for very low jitter at very low frequencies sound better in DACs. Try it you will like it is all I can say.
EDIT: Regarding ESS and clock jitter, they have a white paper on their downloads page. They say so long as the clock used locally by the DAC is good, that the clock, cabling, etc., sending audio to the DAC doesn't need to have such a clean clock. The DAC will use its own clock and ASRC to fix the incoming data. The clock replaced in the mod was the DAC's own clock. (Just so we are clear we are all talking the same thing.)
Don't know about any measurements made with the clocks currently shipping. If measurements showed the original clock to be pretty good, it would be very interesting to replace the clock with an ultra-low jitter and measure again. It is always nice if sense can be made out of all the data.
Mark, your insight on high end gear is much appreciated. But we are talking different animal here. My reference point is the Topping D50 DAC which currently sells at $250 ($199 in DROP earlier). The review and measurement looked very good.
Review and Measurements of Topping D50 DAC | Audio Science Review (ASR) Forum
It is not the $2200 DAC that you referred to. My question at this DIY forum is whether I can build an improved ES9038Q2M DAC for less than the Topping. The -106dB D+N of the Topping D50 is much better than the -70dB you quoted. I do understand that THD measurement is not very meaningful to audible results. I just use the parameter that you mentioned first.
There are positive report on the Chinese ES9038Q2M boards in other threads on this forum. It is true that the quality may vary, but this is one of the good one.
ES9038 Q2M DAC DSD Decoder Support IIS DSD 384KHz Coaxial Fiber DOP USA | eBay
- Digital Line Level
- ES9038Q2M Board
