Simplistic mosFET HV Shunt Regs
First you would need a higher voltage rated Q1 like the IXTP01N100D then you should use higher value R9 R10 like 82k. Watch the isolation to main sink be good and better use a sturdy Schottky diode instead of the D3 Zener for faster low threshold clamping.
Thanks! I don't quite understand "use a sturdy Schottky diode instead of the D3 Zener for faster low threshold clamping". I actually don't understand what this diode does, or how the error amp works, so... could you recommend a specific part?
Its a protection measure for Q5 and Q6 while C2 charges and there is voltage difference or for when there is bad handling or some transient. Say an MBR1100. Same orientation as the silkscreen shows for the D3 Zener.
using IXYS MOSFETs in HV application
As you can see in my previous post, IXYS made several depletion mode FETs, but only some practically usable in tube DIY.
High (500...1000V) voltage, low -few hundred mA- current (smaller surface=smaller capacitances), moderate Ciss, extra low Crss and Qg (charging storage).
RDS(on), dissipation (PD) and thermal coefficient (RthJ) are not so important.
Hi Salas,
I have a similar request for more than 400V, and don't have IXTP's locally, but what I can find are for example: STP3NB60, BUZ77B (600V) and IRFBG30 (1000V). Can I use some of those?
