I've been experimenting with an IB push-push sub in the wall between lounge and hall, that works very well, the ultimate in many respects
And then you can brag about having the biggest system. Heated debate at the pub: "You think you have a big stereo system? Hah! I LIVE INSIDE my sub!"
... You lost me there.
Are we talking about the collective motion of a large number of self-propelled entities?
As in everyone left the pub to party inside your subwoofer?
Yes, looked into that too, and active absorption, it's never ending, perhaps I will more outside, no, hang on, there's only me to please in my one listening spot, this makes things much easier?
It's friday. Let room modes outside the listening spot be left to themselves.
Better get a beer, put on some good tunes and "get your smug on".
I've been asking too much of my Eikonas, I'm experimenting with 12dB/oct, still at 100Hz for the time being, sounds smoother, better between 100-200Hz. Using the Bessel at the moment, I've been reading up about it, evidently it's not easy to implement as a high pass analogue filter, I presume that isn't an issue done digitally?
Bessel works really well for me with DSP.
Try a 3rd oct or 4th order LR HP at 160-190hz, with 2nd order bessel LP at 100-120 or thereabouts. Toss in some butterworth to compare.
Mix'n'match, it is quite interesting. Bessel + Butterworth can work very well.
Edit:
Over ca 7-900hz I keep coming back to 2nd order Bessel HP+LP, time and again. Especially for coaxials. Below this freqency range nothing is sacred, everything can work if matched well. I personally prefer to avoid filters sharper than 8th order.
Edit:
Hi, I'm using 4th order Bessel now LP and HP at 100Hz. Subs in stereo again due to larger overlap. I did try 2nd order but had problems with the cavity resonance again. The region 100Hz to 200Hz is a lot flatter and sounds punchier
Have you tried comparing filter types?
And if you use 2nd order bessel on the subs you should go 3rd or 4th order high pass at 140-180hz somewhere. I think it is a bit backwards to call it a cavity resonance, because there is nothing in the cavity causing any resonance, but merely the cavity combined with panel lengths that actually starts being effective. It is not a curse, it is something to take advantage of.
Glad to hear you are happy with stereo subs, I think it makes a difference.
Subjectively I can't hear much difference with types, just a smoother transition with order.Have you tried comparing filter types?
Why, wouldn't that leave me with a large hole?And if you use 2nd order bessel on the subs you should go 3rd or 4th order high pass at 140-180hz somewhere.
It's commonly called cavity resonance, I understand it is a short TL, so it is a resonance.I think it is a bit backwards to call it a cavity resonance, because there is nothing in the cavity causing any resonance, but merely the cavity combined with panel lengths that actually starts being effective. It is not a curse, it is something to take advantage of.
It's definitely better at the slopes I'm usingGlad to hear you are happy with stereo subs, I think it makes a difference.
No hole. Because the rising response of the subs will contribute up to a point, and be flattened out against the filter. Then the roll off from the filter catches up and this is often a good transition point to xo.
Active filter solutions are great. so much to play with.
- Subwoofers
- Stereo or Mono Subs Xover at ~100Hz
