John Curl's Blowtorch preamplifier part III
But not suprising, given JC's low opinion of them that the JC3 is suboptimal in MM mode. Then again not many people in the market for a 3K+ phono stage even consider MM. The shame is I am convinced that a lot of people* don't realise what they have missed out on.
*where people means us group of strange deluded individuals who still have vinyl collections 🙂
Dude, ridiculas, you've been the black cloud over this thread since you decided to scribble your ravings. So cut the whining, and look at your own posting history.
Several of the solder joints look a little thin, but that's it. Mark pointed out the oddities, but that's all they are. Heck, I'm sure John isn't even involved with the manufacturing.
OK guys, here is the schematic. We make this design cheap enough today, that if you want to duplicate it, waste your time. '-)
Yes, Parasound is my 'cost-effective' version of what I design. I can't afford any better, can you? I don't completely approve of everything that the manufacturers do to save a little money here and there, but mostly they conform to our wishes. Personally I use SN62 Cardas solder for everything that I personally make, and better then FR-3 board material, including Teflon for the Blowtorch, but you know, extra care costs time and money, and THEY DON'T SCRAPE THE LEADS! '-)
The Vendetta Research discrete all-fet phono stage is a better circuit, but we had to make do with IC's, so I did my best. The input op amp could be swapped for a fet input IC or even a 5534, but then the moving coil option would be lost.
Just curious... who own the IP for this circuit?
1642 Would be a good start. AD released a very nice jfet input opamp recently but can't remember the code. Won't be in dip8 though.
Edit -- Hah! Chris beat me to the punch. IIRC the 2140 is a 1642 binned for DC precision. And thanks, Patrick!
