B1 with Korg Triode
Read Mr Pass article.
Mouser has run out of stock for 2Sk 370.
You can find LSK170 in DiyAudio Store or next
source for genuine 2SK170 BL = 2SK370 jfets are
4x Toshiba Original 2SK170BL (2 Matched pairs) | eBay
Have fun :magnet:
Did I not post this?
Thanks Mr Pass
From updated B1 Triode article "....the sound is extremely good , the kind of sound we look for...."
and " ....in the right circumstances it's a very impressive piece.... "
Holy soldering smoke 😀 no comments
Pete uses the 2N7000 N channel Mosfet. The Toshiba/LS 2SK170 or
2SK370 have opposite pinouts, so you just turn them around. After that,
you want to note the different Vds, which is about 4V for the Mosfets and
0V for the Jfets, so the input bias voltage resistors would be adjusted
accordingly.
And as PM notes, you want to add a Gate stopper resistor on the Fets.
Correction: you can leave the input bias resistors the same.
