Amplifier IC for monitor speakers
I am looking at building a pair of monitor speakers for a radio studio. I am looking at 22W full range drivers, so I was thinking about a 35W amp. I obviously looked at the LM3886 IC, but I think it might be overkill. While not really an issue, I was hoping to find a lower power IC, that could potentially accept +-18V so I can power it from a 36 or 48VDC supply.
Please let me know if you have any insight or tips.
Thanks!
LM3886 will run perfectly well, loafing, at +/-18V.
It needs 9V on the - side to overcome the undervoltage cutout; you have double that on tap.
There's no such thing as "overkill" in a radio studio. While the afternoons may be tame, the overnight DJ gets crazy.
And custom work may have a long service life. I ran LM377s in a smaller job from when they were new till past the end of production. I got lucky and noted the EoL, ordered my lifetime spares then, and left town a few years later with two spares taped to the box. LM3886 is more popular than many others and supplies may be around longer.
I like listening as soft to moderate levels most of the time.
Measuring with a (probably not highly accurate) iPhone app SPL meter, from where I sit at 2 meters from speakers, if I turn it up so that peaks in music content are 75 to 80 dB, it's moderately loud to me. If I really crank it when my fav song comes on, then 80 to 83 dB peaks seem very very loud to me!
I think all of this means that I am using 1 watt most of the time, and 2 watts to 10 watts on rare occasion. Still I think there's an advantage to having more power available than what I need. The Amp is not having to work as hard. Is this called headroom?
Thanks!
That should be +/0/- voltage supply.
You can only use a power supply with a zero volt line.
You probably know that but I have seen people use power supplies without the zero volt line and fry things.
Given both the 3886 and 1875 have AVmin of 10, I'd err on using the 3886.
Probably more gain than you want, but still!
Also might be worth seeing if there's any decent kits using the smaller TDA32XX class-D chips. But nothing saying you cannot run the 3886 off a single 36V SMPS as long as you use the single-ended circuit in the DS (I think it's in there!)
Currently listening to background music while browsing. My amp has nice power VU meters. The current track is lively and rather louder than what was on until now. I am seriously considering lowering the volume. The VU meters peak at about 1W. The loudspeakers are of rather low sensitivity. A pair of KEF Carlton III.
