My situation:
I do have an hybrid ESL. This lacks HV voltage on the HV-unit. So I've got myself an external HV unit:
220v High voltage electrostatic generator power supply air purifier 10000v outpu in 220v High-voltage electrostatic generator power supply air purifier 10000v outpu van Hoofdtelefoon Versterker op AliExpress.com | Alibaba Groep
This external unit is in between 3000 - 10.000 volt DC. So this is nice thing to use on the HV for the foil.
So the question is how to connect this unit to the foil and the audio-transformer of my ESL.
I will connect this to Audiostatic ESH100:
ESH100 audiostatic - Google Search
So how to connect this on the ESL system?
I have seen several different ESH100 circuit configurations...So the question is how to connect this unit to the foil and the audio-transformer of my ESL.
If you can provide a picture of the existing power supply board in your ESH100, the best connection method can then be determined.
