Russ,
Any news on the 8CH version BIV?
thanks
I am waiting for that too!
And me, too... I have a pretty elaborate setup for active 4-way speakers with miniSHARC, Cronus, and a bunch of other TPA boards, all assembled, waiting for the new 8-channel DAC. And now, with the 8-channel Buffalo-III apparently discontinued, I'm kind of stuck...
How does a typical DIY-build of Buffalo III-SE-Pro 9038 measure (SNR, THD+N, crosstalk)? Can it get close to a Benchmark Dac3 performance for a "normal" build?
Russ,
thanks
Hoping for it too: would be a great update for my software XOver system!
well...
No one has posted any measurements yet... Got to get one into the hands of someone with an AP. Certainly it should measure quite well, if someone does a good build and layout job.
Subjective sound quality of my Buff PRO (9038)/Mercury build certainly is better than anything I have heard at less than $10K retail.
I can not find any measurements when searching the web.
I hope it is me just not finding it, or did you all buy it without knowing how it measures?
Mercury would be most interesting for me, because I am interested in the coming 8-channel dac.
But any would do, just to see what kind of end-result performance can be realised with the TPA-stuff.
I don't know if you can find that, almost everyone has unique setup, ps, I/V, regs... Maybe Russ & Brian have a "reference full TP" DAC and then can give numbers, don't you guys?
I don't have access to an AP (they cost about $30K) - but ESS measured the IVY circuit + ES9018(B32 in this case) for us. B-II,III etc are all using the same DAC (ES9018).
-117db THD+N and ~129db DNR(stereo)
That output stage was identical in function to the IVY-III. Mercury is also very similar.
I have measured (on PC using sound cards) all of my modules - but those measurements are limited by the capability of the sound card ADC etc. I don't consider them very accurate - just a sanity check.
Also note that for any balanced output DAC you need a fully differential ADC on the test instrument in order to measure it accurately. The balanced output will always be superior to the SE output - but measuring differential signals by the difference of 2 SE channels is not ideal - because single ended each channel will have its own errors. That's why I would love to have an AP. If anyone wants to donate one let me know. 🙂
Thanks, nice figures!
And crosstalk?
A large spike at 1KHz in that diagram, something to worry about?
And crosstalk?
- More Vendors...
- Twisted Pear
- Introducing the Buffalo III-SE-Pro 9028/9038
