FYI according to Wilmslow audio this driver is being withdrawn from DIY market. ATC SM75-150 Midrange
ATC thinks that this decision boosts the sales of their completed speakers?
I love this thing, it is one and only, so I might pull the trigger finally...
Well, curiously, they are not withdrawing it entirely, just DIY market. Seems bulk buyers will still be able to get it?
E
E
May be but only as long as they do not enter the active monitor market.
ATC has already stopped supplying manufacturers like Quested, PMC and Klein+Hummel (Neumann) years ago which is why the Volt VM752 exists, PMC is manufacturing their own and K+H simply ceased making their top model.
I just saw this news as well. This sucks. I was really looking forward to trying these out in the future. And what's worse is if something happens to one you won't be able to run out and order another pair. Boo!
In certain part of the world ATC has always been unobtainium...
Very strange people...I have stopped bothering their dealers for years...😛
I strongly hope that ATC at least replaces damaged or malfunctioning units when they were bought before they withdrawn it.
Othewise I'd be pretty concerned IF something ever happens with one of the drivers.
Usually they don't blow up but what IF so... 😕
They will probably do the same as Dynaudio did when they stopped selling bare drivers:
You'll have to send in the dead unit to get a replacement.
Wonder if they would entertain a DIY group buy. We weren't going to buy their speakers anyways.
Probably not.
The Volt looked good in VoiceCoil. I prefer the power response of the ATC though.
Probably not.
Definitely NOT !
Frankly, the Volt sux balls compared to the ATC.
THD values and frequency-response are nowhere close to ATC and their higher Fs at 400Hz makes it impossible to crossover around 380Hz like ATC.
It needs a minimum of 500Hz..
And then its even more expensive lol .. wonder if they sell these 🙄
What is your reasoning behind insisting that the Volt needs to be crossed 100Hz above Fs while the ATC can be crossed at Fs?
The ATC is not crossed at Fs but also some 100 Hz above:
http://studio-hifi.com/images/ATC75-150S_JeffBagby.pdf
what pieter says 😉
I hope I can be forgiven for a bit of a high jack here but this is a perfect thred to ask this question...
If there was a ribbon no more than about 6 inches long that could be crossed at
500hz would there be interest?
And do you believe that crossing at 380 would make a big difference ( assuming a ribbon close to same length could do it)?
If it can do 111db with 1% distortion...could be interesting.
On the subject of domes, I wonder how a Radian 4" diaphragm with the backcover removed would compare to the ATC. I know Radian can supply shims if you want to get more output on the low end. It would need to be crossed a little higher though.
Not familiar with Radian , link?
The ribbon is .6 % at 500hz at 100db 1 meter (2nd order LR ) , down to .3% at by 1khz. Patent for the design is being writen now. FR is +- 1.5 db 200-15khz, down -3db by 20k
Be sure to start a thread when the production model is ready. It'll be a winner for most domestic uses if the price isn't more than a Beyma or Raal.
https://radianaudio.com/products/951pb-compression-driver/
951PB Compression Driver – Radian Audio
start a thred....
is that allowed here for a manufacture?
- ATC SM75-150 withdrawl
