Aksa Lender P-mos Hybrid Aleph (ALPHA) Class A Amp GB
Founder of XSA-Labs
Joined 2012
The technical discussion thread for the ALPHA amp is here:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Thank you AKSA for design and inspiration, JPS64 for layout, and Nelson pass for Aleph CCS!
This is a spin-off from the above thread to keep discussions to the group buy and the build process separate.
Schematic for 20W ALPHA:
660029d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_schematic-v4-png
Parts placement:
660032d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_topview-png
3D render:
660030d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_3d_render-png
Example build with Vishay-Dale/Wima/Silmics:
666395d1520249706-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-premium-build-02-jpg
Another example with non-premium resistors:
661735d1518324741-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha20-amp-build-02-left-jpg
Alpha 20 with 1.31amp bias and 2.86vrms into 8ohms gives 0.0069% THD, 0.0059% if using all Vishay-Dale:
661737d1518324741-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20-2-87vrms-8ohms-fft-png
BOM and Schematics here (note that there is error on R108, should be 47R not 470R, and for R131 and R132, use Pan ERX 3W 0.47R and 0.22R, respectively for 1.35 amp bias:
http://www.diyaudio.com/forums/soli...rid-aleph-alpha-amplifier-51.html#post5348523
Corrections to previous BOM in BOLD
Feb. 20, 2018 v1
Position Mouser # Mfg # Product Description
R101 594-5063JD2K200FT MBA02040C2201FRP00 Metal Film Resistors - Through Hole .4watt 2.2Kohms 1% 1/8watt body size
R102 594-MRS16000C2202FRP MRS16000C2202FRP00 400 mW Thin Film Resistors 22Kohms 1% 50ppm
R103 594-MRS25000C3301FCT MRS25000C3301FCT00 Thin Film Resistors .6watt 3.3Kohms 1%
R104 594-MRS16000C6801FC1 MRS16000C6801FC100 400 mW Thin Film Resistors 6.8Kohm 1% 50ppm
R105 81-PV36Y202C01B00 PV36Y202C01B00 Trimmer Resistors - Through Hole 2.0Kohms 10mm Square 25turn
R106 594-5063JD220R0F MBA02040C2200FC100 Metal Film Resistors .4watt 220ohms 1% 1/8watt body size
R108 Metal Film Resistors .4watt 47ohms 1% 1/8watt body size
R111 594-5063JD820R0F MBA02040C8200FC100 Metal Film Resistors - Through Hole .4watt 820ohms 1% 1/8watt body size
R112 594-5063JD220K0F MBA02040C2203FC100 Metal Film Resistors .4watt 220Kohms 1% 1/8watt body size
R113 588-OK2235E-R52 OK2235E-R52 Carbon Film Resistors 22K Ohm 1/4W 5% 250 Volt (ok to use high quality Vishay-Dale 1% metal thin film here)
R121 *correction* 1k 1% metal thin film
R122 594-5063JD2K200F MBA02040C2201FC100 Metal Film Resistors .4watt 2.2Kohms 1% 1/8watt body size
R123 594-5063JD1K500FT MBA02040C1501FRP00 Metal Film Resistors - Through Hole .4watt 1.5Kohms 1% 1/8watt body size
R124 594-5063JD100K0FT MBA02040C1003FRP00 Metal Film Resistors .4watt 100Kohms 1% 1/8watt body size
R125 652-3296W-1-204LF 3296W-1-204LF Trimmer Resistors - Through Hole 3/8" 200Kohms Sealed Vertical Adjust
R126 594-5063JD220R0F MBA02040C2200FC100 Metal Film Resistors .4watt 220ohms 1% 1/8watt body size
R1270 81-PV36Y202C01B00 PV36Y202C01B00 Trimmer Resistors - Through Hole 2.0Kohms 10mm Square 25turn
R127 594-5063JD1K400F MBA02040C1401FC100 Metal Film Resistors .4watt 1.4Kohms 1% 1/8watt body size
R128 594-5063JD680R0F MBA02040C6800FC100 Metal Film Resistors .4watt 680ohms 1% 1/8watt body size
R129 594-5063JD220R0F MBA02040C2200FC100 Metal Film Resistors .4watt 220ohms 1% 1/8watt body size
R131 0.47ohms 3W Panasonic ERX
R132 0.22ohms 3W Panasonic ERX (or two 0.47R in parallel is ok too)
Do not use thick film metal oxide or inductive wirewound here
C101 505-FKP2D002201D00HA FKP2D002201D00HA00 FKP - Film Capacitors 220 pF 100 VDC 2.5%
C102 555-RFS35V100ME3#5 RFS-35V100ME3#5 Aluminum Electrolytic Capacitors - Leaded 10uF 35V 20% Audio SILMIC II
C103 *correction* use 470uF to 1000uF 35v is ok and no audio passes through this cap but large 1000uF prevents turn-on thump.
C1020 Bypass 871-B32523Q1225K B32523Q1225K000 22.5mm LS Film Capacitors 2.2uF 100volts 10%
C1020 (alternate) 75-MKP1848610914P2 MKP1848610914P2 Film Capacitors 10uF 1100volt 5% 2pin 37.5mm LS
C1021 80-PHE426HR8100JR6L2 PHE426HR8100JR06L2 Film Capacitors 250volts 10uF 5% LS 37.5mm
C1022 871-B32672P6105K B32672P6105K Film Capacitors 1.0uF 10% 630Vdc MKP PFC, LS 15MM
C105 581-12061A180FAT2A 12061A180FAT2A Multilayer Ceramic Capacitors MLCC - SMD/SMT 100V 18pF C0G 1206 1%
C111 555-RFS50V102MK9#5 RFS-50V102MK9#5 Aluminum Electrolytic Capacitors - Leaded 1000uF 50V 20% Audio SILMIC II
C112 505-MKP2J021001E00MS MKP2J021001E00MSSD Film Capacitors 0.01 uF 630 VDC 20%
C113 581-12061A180FAT2A 12061A180FAT2A Multilayer Ceramic Capacitors MLCC - SMD/SMT 100V 18pF C0G 1206 1%
C115 505-MKS2C041001FJC00 MKS2C041001F00JC00 Film Capacitors 1uF 63 Volts 5%
C121 505-MKS4C041002EKSSD MKS4C041002E00KSSD Film Capacitors 1uF 63 Volts 5%, 7.5mm Lead spacing
C122 647-UFG2A221MHM UFG2A221MHM Nichicon Aluminum Electrolytic Capacitors - Leaded 220uF 100 Volts 20% Tol.
C122 alternate 555-RFS35V221MI6#5 RFS-35V221MI6#5 Elna Simic II electrrolytic 220uF 35v
C128 647-UFG2A221MHM UFG2A221MHM Nichicon Aluminum Electrolytic Capacitors - Leaded 220uF 100 Volts 20% Tol.
C128 alternate 555-RFS35V221MI6#5 RFS-35V221MI6#5 Elna Simic II electrrolytic 220uF 35v
C127 505-MKS2C041001FJC00 MKS2C041001F00JC00 Film Capacitors 1uF 63 Volts 5%
V101 512-KSA992FBU KSA992FBU Bipolar Transistors - BJT PNP Epitaxial Sil
V102 512-KSA992FBU KSA992FBU Bipolar Transistors - BJT PNP Epitaxial Sil
V103 512-KSC1845FTA KSC1845FTA Bipolar Transistors - BJT NPN Epitaxial Sil
V121 512-BC547CBU BC547CBU Bipolar Transistors - BJT NPN 45V 100mA HFE/800 - TO-92-3
V131 844-IRFP240PBF IRFP240PBF MOSFET N-Chan 200V 20 Amp
V132 844-IRFP9240PBF IRFP9240PBF MOSFET P-Chan 200V 12 Amp
D035 78-1N4148 1N4148TR 500 mW Diodes - General Purpose, Power, Switching 100V Io/150mA T/R
X141, 142, 143, 144, 131, 132 534-1287 1287 Keystone Terminals .250" PCB TERMINAL
X101 571-3-641213-2 3-641213-2 TE Connectivity - Headers & Wire Housings POLARIZED HEADER 2P Straight Post gold
ALPHA 20 Group Buy PCBs are $28/pair with $5 shipping to USA, $10 to Canda, and $15 everywhere else.
Current list of GB2 for ALPHA 20:
danibosn - 2 sets
Yoaudio - 1 set
BRN - 1 set
pieter t - 1 set
danny_66 - 1 set
jvojvo - 1 set
postip - 1 set
tonza75 2 set
spind - 1 set
mk15 - 1 set
*** 52 Watt Version ***
Here is the 52W Big Boy (BB) version of ALPHA coming up soon. Waiting for beta test to verify functionality.
667515d1520672272-aksa-lender-mos-hybrid-aleph-alpha-amplifier-bb-1pn_pba-jpg
Edit April 4, 2018: as-built schematic for Alpha 20 for 1.35amp bias.
673097d1522861468-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20-schematic-updates-1-35amps-built-png
Edit April 15, 2018: ALPHA BB GB is proceeding. Cost of 1 pair of 2mm thick FRP, 2oz copper, ENIG finish is $60. Shipping in US is $8, Canada is $17, everywhere else is $24 (10oz weight 240mm x 130mm size is expensive to ship).
Schematic for v2:
675435d1523845018-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-production-schematic-v2-jpg
Parts placement for v2:
675436d1523845018-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-bb-production-top-view-placement-v2-jpg
BOM for v2 is here.
Hi X, why not try doing something different and add a new flair to the project. How about using say an LM337 for the CCS because it is simple to fix the current using a single resistor. Get rid of V121. See how much different it sounds if at all. You can then add your name to the list of designers.
V121 is a critical part of the dynamic Aleph CCS by Nelson Pass. Take that out and it is no longer an Aleph. The power efficiency will go down, and the name will not be ALPHA, but ALPHC (doesn't have quite the same ring, does it?) 🙂
I say why not change it to LM337 then V121 is unnecessary and it is not an Aleph output stage. It becomes an XRK971 output stage. Oh well I did try to nudge you a little into being daring and making some changes see if it affects the sound at all.
If you do not have an electronic background then I fully understand your reply then forget my I suggestion sorry.
It’s not that I don’t want to try, I have already built another amp with an IRFP240 CCS (controlled by LED) with an IRFP9240 P channel output below. It is the Silicon Harmony. It sounds great but is not as power efficient. In SE Class A mode, the Aleph is a dynamic CCS and will give more of a push-pull character to increase swing. As the very nice PCBs designed by jPs64 are already made, and the amp measures and sounds great, Inhave no need to try an LM337 for the CCS. Besides, isn’t that basically adding 15 transistors of a sort of opamp IC to this simple and elegant 6 actives Class A circuit. Can LM337 handle 4amp current swings?
I did my own amp nods a few projects ago (FH9 Xrk mod being my favorite).
I placed the capacitors order from S Korea based on the circuit was drawn by X for this amp and some other projects.
Just realized now when I was checking out this thread the picture X posted (why that capacitor size so large) it is 1000uF not 100uF.
Instead the 47uF I ordered 100uF.
My fault I did not found the BOM when I placed the order so I used the circuit was at hand:ashamed:.
I also used that to do my layout with the 3 pairs.
6 Weeks until the package arrive if I order it again another 6 weeks. Yeak.
I have at home some Panasonic FC type, not my favorite I think to test the amp it will do the job.
Now the GB will be separate, this way can be better organized.
It is a great idea.
The 1000uF 50v feedback shunt cap, can probably be made 220uF with no problem - Panasonic FC is a fine cap. I know what you mean about overseas orders though. Sometimes best to order several values so that it can be used on other projects too rather than on a per amp basis. Good luck with your Alpha build though.
Alpha 20 GB2 Status Update...
danibosn - 2 sets
Yoaudio - 1 set, invoice sent
BRN - 1 set, invoice sent
pieter t - 1 set
danny_66 - 1 set, invoice sent
jvojvo - 1 set
postip - 1 set (no PayPal in Turkey, looking for alternate method)
tonza75 2 set
spind - 1 set
mk15 - 1 set
mrk7 - 1 set
Just a reminder to please send me your PayPal address if your name is on the list.
danibosn - 2 sets
pieter t - 1 set
jvojvo - 1 set
tonza75 2 set
spind - 1 set
mk15 - 1 set
mrk7 - 1 set
ekidnah09 -1 set
That’s a funny scale. Do you think people subjectively can differentiate 13 levels of sound quality vs 10? Let’s keep this thread on topic though. This is the GB thread and discussions should be about getting and building the amp.
That is an odd scale. For ~$16USD*, I think they are a great deal. They aren't cheap, but compared to other caps on that page, they are economical IMO.
*ClarityCap 10 mfd CSA Range with CopperConnect Technology
