New FIFO buffer for RPI/SBCs
I think that Ians took a different route with his design
No question!
However.
I'm not talking about tweaks here!
Ian introduced a seperate HAT for the outputstage.
This way it can easily get swapped. This is what you IMO should look at at.
Many people appreciate output transformer stages. They prefer them over
opamp stages. I'm just saying... 😉
And then there will be people who'd love to see a tube-HAT-stage. 😀
It's about future options.
All that doesn't mean opamp stages - if done right - are a bad thing. 😀
It's a good option to start with.
Apple to apples its the right way..however a lot of the N in the THD+N comes from actual PSU and some (in testing) from the Gdn of the RPI.
THD is more from the dac design and analog stage.
Does the power/control board act as an isolator between the Pi and the rest of the stack, or would you need to use the isolator board in addition to the 3 board stack to remove noise coming in from the Pi?
No question!
However.
@Soundcheck,
I'm a bit confused by what you wrote. Allo has had a separate output stage board in the Katana design from the beginning:
Hello DimDim
yeap we had to do it 3 story high. The DAC is connected to i2s so no DSD..checking for DOP (I assumed its compatible)
In any case the design was very complicated , we used lots of LDOs and filtering on both 3.3v , 1.2V and + - 15V (for opamps) . Placement was difficult , but by using 3 decks we separated dirty grounds from clean grounds (not isolated)..and we placed the powers on proper places. Like I said...difficult. <SNIP>
Ioan,
I for one am eagerly awaiting this. While there are other R-Pi-based DACs with pretensions to high-ish-end (I'm thinking fo the Terra-BerryDAC2 & the TauDAC as ones that appear to actually have made it to release), none combine the array of features, flexibility, & reasonable cost that you're projecting in this DAC.
I'm excited by:
<SNIP>
2. Multiple-board stacking. One of the biggest issues with getting great performance out of an RPi DAC is the limited board space. Stacking gives you much more flexibility to the manufacturer do great things (such as better output stages and better power) by providing more circuit board real-estate... along with...
3. Flexibility. By separating the main board, output board and power board, you provide for a level of flexibility in options, upgrades, and meddlesome tweaking and modifying like I am wont to do.
<SNIP>
3 board stack
1.ess sabre , 2.analog board output with discrete opamp , 3.control and voltages.
I'd say the difference between Allo & Ian's approaches is that:
- Allo's DAC is intended to give you the best SQ they can manage in a R-Pi DAC HAT-sized set of boards that can be easily by a single 5V supply, but provides some flexibility for tweaking.
- Ian's approach is to give you very good sounding DAC base and one (or maybe eventually more) output board(s) where you can roll your own.
The 1st is great for a product that can be used by a wide swath of consumers, the 2nd is great for many of us DIY'ers here in DIYAudio.
I'm happy that both are out there and intend to use both when they are available.
Just my 2 cents.
Greg in Mississippi
P.S. For a DAC HAT with a separate transformer output stage already available, you can go buy a TauDAC at about 650 Euro.
Hmmmmm....we found out that our AP machine has a noise of 6uV on RCA and 10uV on XLR by default ( using loop back).
Our noise in RCA is of 13uV right now and 25 of XLR (removing base noise thats 7uV on RCA and 14 on XLR)
THD+N is solved. I don't have the exact calculation but its better than -105 THD+N on both RCA and XLR (1Khz). 🙂
Final version of PCBs (after measuring and tweaking every power rail , about 45 different ones) is being worked on and will sent to PCB house for mass production.
Also as a side note , we have developed the 5V SMPS that goes along with it. 10 days to new prototype. We expect to set a new record in 5V SMPS ( low noise) in both input (towards mains) and output (towards your DAC/RPI) . Special attention was directed towards "leakage currents" on output and EMI reduction at the source. (diode and mosfet)
Its hard to explain how many hours we slaved in reducing loop area on mosfet (imagine a tetris game) we changed the mosfet 3 times , last time to gain about 4mm sq (less) of loop area . Also ferrite beads were strategically placed in gate driver , drain and r2dc snubber (+ 2 on source resistors)
Along with less EMI , we have as a side effect that we need less Y capacitance to pass EMI test and less Y capacitor = less leakage .
No it does not. This week we have scheduled to test the isolator board as well to see whats the reduction in noise. However when you arrive at 6-7uV its hard to see the improvement.
Its been weeks that we are in testing now, we have hundreds of reports.
Unit sounds..like a ess9038q2m with a class A stage..
Noise on oscillators rails is 600uV , analog stage 900uV . Everything is under 1mV.
This week we might release the driver of the DAC , or rather the driver of the MCU.
We have final PCBs , we will check it a few times and send it to PCB house
Great to see the progress.
My Qs:
1.
I don't see any supercaps as buffer or any other special caps you've been using on e.g. the Boss for the analog part!?!? Budget? No need anymore ?
Especially on class-A I'd expect plenty of local & fast power to be
a rather good idea.
2.
I don't see any external power options (jacks/jumpers) as we've been discussing several times for your other products!?!?
I mean, you applied related changes to e.g. your recent Boss revision.
Change on strategy once more?
3.
Will the new 5V SMPS, that can probably be used with the new HATs, also
be launched in conjunction with the new DAC?
My Qs:
1.
a rather good idea.
2.
3.
1. They are there on the ess9038 PCB (better even then Boss)..dual
2. On the analog stage , not present , present on the controller board . You can feed external 15V. For the 5V you have 2 ways of feeding it + you can feed the RPI independently . I will try to make a doc explaining it.
3. Next week I will have a definitive answer on the SMPS (testing the latest PCB)
Ah. There's another board. A controller board!?!
That's sounds more than just a power controller / power board!??
But that one at least generates +/-15V from 5V - doesn't it?
Only one 5V SMPS would than be required for this HAT solution!?!
Things are getting more complex by the post. 🙄
You said. You'll write it all up. We'll be patient.
Just to mention it.
The supercaps and these caps that'd been suggested by Greg (forgot the type) on the Boss do power the Boss DACs internal opamp output stage.
At least that's IMO their main benefit.
What sense does it make to have them now on the DAC HAT only!?!?
To me it'd even make more sense to have them on the output stage.
Anyhow. Never mind. I'm not the HW expert here. I do know usually
you have your reasons for doing things the way they are done.
In the end, what matters is the final result! 😀
I think it would be great if you'd launch both products DAC and SMPS at the same time. Or better, the SMPS first.
It's better from a marketing perspective. 😉
Is Volumio site going to offer the Kali + Piano 2.1 bundle again
The Volumio site shows out of stock.
Or is there a more important reason why it is no longer offered?
And BTW. What's the general consensus if my goal is to BiAmp (tubes on top, SS on the bottoms) using the Piano 2.1?
My current streaming source is a RPi I2S connected to a HFiBerry DAC running Volumio on the RPi. I know much has matured in this space, and I want BiAmp and a volume control in the app.
I see that the Piano 2.1 is out of stock at Allo.com too. No doubt they would be able to tell you when new stock is expected.
Quite a few people (including me) like the Kali/Piano2.1 in dual mono mode best. However , if you are biamping you may prefer to use dual stereo so that each amp has its own input.
you prompted a question...
Have the problems with setting the crossover point in 2.1 or 2.2 mode been solved? Do I still need the TI software to adjust? ... or is the crossover adjustable from the Volumio user interface? And exactly what can I adjust from Volumio?
Are there things I can adjust from the TI software that I cannot from Volumio (assuming I can adjust anything from Volumio)?
Has the process of getting the TI software gotten easier?
Boy! what a bunch of questions...!
Which crossover problems ? Volumio allows you to select the crossover points.
The TI software allows you do to any processing you want (subject to the DAC memory and processing time available in the sample period). Getting a license from TI is very slow and may take a few attempts.
