I can only assume you don't know what the term 'hi-fi' means.
I can only assume you, like most people don't hear the room and audience which make up most of the sound that reaches your ears at a concert.
You're being too harsh.No, they are band-aids for poor storage media / recording technology.
Band aids perhaps but each storage medium and each storage method has drawbacks.No, they are band-aids for poor storage media / recording technology.
Not so much hidden but rather not displayed in the form thats easy to understand.That is explained in graphs and words in the chip datasheet, it's all there, nothing hidden.
Scott.. yes the sales pitch is always to be treated with caution.The trouble is, it doesn't, not by any stretch of the imagination. When you read the manual and datasheet do you believe the hyperbole? (I'm being polite)
I'd say that rephase ...whatever it is cant really be appreciated if its not taken up by companies in their products.Because it's cheap and simple just what big consumer electronics companies like. It could make some very poor equipment sound exciting. You won't see rePhase in a consumer product because it isn't one.
I dont think a 360 degree phase shift sounds right does it... still its used all over the place which attests to its effecavasy. ..sorry for spelling.Phase manipulation does have value, you only have to look around this site, rePhase for example. What the BBE does by taking two wide bands of frequencies and shifting one by 180° and the other by 360° is not the right way to go about it. It is taking a sledgehammer to crack a walnut and in the process will make a big mess.
A phase shift of 360° does add up to the same amplitude but the impulse answer isn't the same. That's not always audible or even rarely except for some A/B comparisons. But the phase shift is caused by something, by a longer way the sound has to travel, by filters or by an actual delay. The problem is, that delay may add up to the same amplitude at frequency x but frequency y does change the amplitude and phase at a different rate and while x adds up to the same, you'll end up with a completely different phase alignment at frequency y. And THAT does not add up to the same amplitude and you can hear that.
