John Curl's Blowtorch preamplifier part III
I have done it with both a Dauphine (many times) and a Porsche (a few times). It is just like listening to the music just for itself, if it is good, then the medium you use is secondary, however, if you want a sports car experience as well, then the Porsche is much better, e.g. high audio playback quality further enhances the experience.
Afoot? Too much Sherlock bingeing on Netflix, ol' chap? You are suggesting I have a hidden agenda and you are infantalizing my knowledge of control theory. No need for that; shall we stick to the higher ground of engineering analysis?
You have an equation in your data sheet that makes the effects of the output buffer completely vanish into thin air "by simple subtraction".
This should not be a surprise because "error cancellation" by feedback is impossible except hypothetically in academic's margin notes.
Sounds like an agenda to me, and an offhand attack on other peoples work.
C-C looks like subtraction to me, so what if it fails at high f the results are posted please comment on my points and the actual data and drop the editorializing. Again as a point of discussion, if the buffer is modeled as an exact G = 1 with no frequency limitations it is simply C-C = 0.
Should we say error reduction rather than cancellation? Such a commotion around a circuit where nothing but a simple capacitor added to an already finished circuit had an unforeseen benefit.
On my point of view, this endless controversy about blind tests VS not blind is boring.
Blind tests are, for sure, useful for two things.
It is the only way to get a "proof". So, it is useful if you want to make a theoretical study about average audibility of people and if you want to lift an uncertainty for yourself.
When some want to make his own opinion on some electro/acoustic gear, in relation to "hifi", or to take design decisions, he is free to choose the methods he think the best for him. I don't need any blind tests to figure out which restaurants I prefer.
I notice one thing. Supporters of "blind tests" would like to impose their "personal" points of view on everyone, the others only choose the methods that best suit them, according to the circumstances. Of course the points of view are subjectives, if they are not scientifically proven. These are just opinions. And I have been taught to respect those of others, even if they differ from mine. More than this, they can enrich mines, sometimes, giving me the desire to check on my own.
Someone on another thread just made the point that an ABX test proves that we are not imagining a difference, so then we can move on to making a judgment about it
Yes, before an audiophile claims a listening preference, it would be good if they demonstrate that they can hear an audible difference.
But the word 'prove' is a stretch. Likelihood is a better goal.
I'm glad that you guys got that sorted out. PMA has properly shown the problem with ceramic caps is: That COG caps never are large enough to be effective coupling caps. ONLY hi Q ceramics like the 7 series has enough maximum capacitance to be useful for a coupling cap, AND they distort BADLY! If some of you idealists would just MEASURE hi Q ceramic caps aggressively, you would find what PMA has found.
Not a single "idealist" disagrees with you here. It's widely known. It's been in app notes and datasheets for at least 15 years. Only an incompetent designer in "hi-fi" would use X, Y, Z dielectric caps for coupling or filtering.
AX tech editor
Joined 2002
Yawn. Yes we know the difference between objective proof and personal opinion or preference since, ohh, I don't know, several centuries?
Jan
OK, where did I find SMD MLCC X7R coupling capacitors? In microphone preamplifiers in consumer and pro sound cards and mixers of various manufacturers. One example is attached. Please note they use excellent OPA1602, on the other hand ....
Years ago I measured a 100nF, 40 years old Tesla X7R capacitor, which was used for supply bypass usually. I have now decided to repeat the measurement with some modern SMD X7R part. Tested capacitor has 56uF, load is 1kohm, which makes 2.8Hz(-3dB) low frequency corner. Quite reasonable, right. Please see loopback measurement (just 1kohm load only) vs. 56uF+1kohm measurement in attachments. Also a photo of the test fixture. (input voltage was 0.5V only).
Many designers use 100pF ceramic caps to filter the Integrated circuit rails. because they are micro-scopic. Arguments against this use?
Generally speaking, no arguments, and 100pF will be most probably COG/NPO, which is fine.
On the other hand, supply rails/PCB tracks bypassing is not trivial and it should be verified that no interfering HF resonances have been created.
