Hello,
I'm having some trouble finding the cause for a hum on a luxman LV-105 (not the u version). Also the right channel doesn't handle any load (dim bulb goes bright and relay opens). Sometimes, not always, the relay keeps kicking in and out without any load connected, at the same time dc offset get up to around 1.5v. The tubes are ok (putting in new ones doesn't change anything to the problem) and the hum is present before them (not in the tone amp though). The caps are all new (checked polarity carefully). Whenever I unplug the connector taking the + and - rails to the equalizer circuit the hum gets slightly lower and the right channel can accept a load again. It looks like the high voltage power supply can't keep up somehow.
Hello,
Hi!
Are there capacitors in the signal line, or is DC coupled everywhere?
There are caps in the signal line at the output of the tone amp IC but from input to output of the power amp it's all dc coupled. I think it must be somewhere in the first stage, right before the tube based differential amp.
Is the hum present when you connect the inputs to ground? Have you tried removing the tubes from the tube stage and checking the output noise with an oscilloscope?
Btw, i would try to find why is there a DC voltage on the output.
The hum is present with inputs shorted to ground yes.
The thing is, it's not consistent, it just moves up and then the relay opens almost immediately so there is no time to see why it does this . There is no dc when the I disconnect the equalizer circuit but there is still hum.
I doesn't come from the equalizer, that works ok, the extra load on the power supply seems to just agravate the problem, the output of the equalizer is not connected to the input of the amp so it can't be passing trough dc.
Are you sure there is no leaky capacitors in the amplifier?
I'm positive, they have all been replaced with high grade caps. Other than the hum it sounds ok through headphones, I haven't tested it with speakers because I don't want to risk damaging them.
That worries me.replaced with high grade caps
Some of the "Hi Grade" offering are scrap that have been relabelled.
I order all my parts from mouser Nichicon FG, ES, Panasonic FM/FC and elna silmic II. I don't think there's anything to worry about there 🙂
I might have found something.
Although I have the right schematic (LV105 not the U version) there are some major differences with what I actually see on the board (for starters the protection circuit is on the main board and not on a separate one as the service manual says).
There were 2 diodes that were eaten up by the brown glue that were marked D7305 and 7306, I didn't think any further and replaced them with an equivalent of the 1s2462. Now it turns out the part numbers are also different in the manual and on the board and D7305 and D7306 weren't 1s2462 at all but what I believe are zener diodes (marked 12C3) and are in place of R7385 and R7386 (8.2K in the service manual) going to the cathodes of the tubes. Can anyone tell me what diode this is and what I can replace it with ?
For an example of a Zener diode look at an angle of 10 o clock from the red circle on your second image see ZD7309 which is defined by the symbol as well as the prefix.
The datasheet for 1s2462 describes these as a general purpose rectifier in a hermetically sealed miniature glass package - the sort of package shown in your first image.
If your replacements have equivalent or better specifications than 1s2462 and are oriented as the board overlay indicates, the only other thing to check here is to ensure there are no cold solder joints.
Hi!
I know what a zener is 😀 , the schematic shows an 8.2k resistor but instead there was this diode from the picture that was shorted (in the red circle on both channels). I mistook it for one of the 2 1s2462 diodes because the marking on the board corresponds but not the implantation in the circuit. The only marking on the diode is 12C3, I googled it but the results aren't very conclusive, I found one that shows this as a 13.8V 1/2W but as I can find this nowhere else I'm not sure.
From this link you can see this being a 12 V zener. It could well be this drops the same voltage from where it is sourced as an 8k2 resistor. HZ12(C3) NTE Equivalent NTE5021T1 ZENER DIODE - 12V ... - Wholesale Electronics
I downloaded the comprehensive service manual and looked at the component lists to identify HZ12 (C3) listed. I see from downloading the pdf from the link the replacement has a 1% tolerance rating.
That does seem to make sense. I just measured the voltage across the diode I installed as a replacement and it was about 80v, no wonder the amp wasn't happy, I don't see how the 63v cap that is in parallel didn't even get hot. Maybe it did do some damage so I might just go ahead and replace it again (it was a new one already). I have some Vishay BZX55 12v 1/2W on order for another project, I'll just add 2.
Just thinking aloud a bit about this - the parts list shows HZ12(C3) or RD15E-B2 as zener options for designated part no. ZD1307. The parts list gives D7305 and D7306 designated part numbers as 1s2462 or 1s2463.
According to the pcb R7385 is a resistor but in the parts list I don't see a resistor or a zener diode with the matching type number 7385. It seems some circuit changes had yet to be documented when the service manual I referenced was published.
If the voltage applied to your diode was 80 volts, substituting an 8k2 resistor in place would result in a negligible drop in the voltage seen by C7307. Nominally limited to 63 volts it many have withstood higher voltages to a point - but not at 80 volts in the long term.
There is only one HZ12(C3) in the parts list - ZD1307 in another part of the circuit. This component would have been in the parts inventory and convenient to use to replace R7385.
I guess that's exactly what they did, I replaced both with vishay BZX85 12v zener diodes and the amp is hum free, the relay stays nicely closed, bias has been set and it now sounds pretty good. Thanks for the help !!
I did some tests today with the new tubes in, it sure seems healthy now, it got up to 105W into 8ohms (rated for 80W) , both channels driven at 1kHz and there still wasn't any clipping. I didn't want to push it because my dummy load is only rated for a 100W. It does get quite hot even with no signal with those 45mV of bias so it will need some space to breathe. It sounded very nice through the headphones and will do some tests later on my B&W DM4.
Hello Debaj,
I was wondering if you can help me with my LV 105...
I have a problem with the right channel which causes the unit to stay in protection.
The symptoms are as follows: when I power up the unit the diodeLD7310 lights up for a sec or two and then goes away. The voltages at the FETs go to round 60. When I power off the unit the diode lights up again for a second or two.
I have checked the FETs and they are ok, also Q7314 is ok. I have recapped the whole unit. Resoldered both the main board and the Preamp PCB. Also managed to set the bias when the unit was going out of protection (this happens from time to time). Also checked Q7312,14 &16 and they are ok. D7306 and 08 are ok.
Do you have any ideas what might be causing the problem?
Thanks in advance!
- Luxman LV-105 hum
