First watt choices
I would really like to build one but I am unsure of which one. My current speakers are have pretty well behaved impedance that stays at or above 8 ohms so they should not be too horrible.
However, it would be nice to have the option of less well behaved speakers too.
Is there and obvious choice?
Room size , which speakers exactly (db/W/m being most important , but not single important parameter) , SPL habits
Gotcha,
Right now I am running so DIY bookshelf Jeff Bagby Continuum. Not super efficient but 8 ohm nominal and no real dips. I don’t really listen loud. But I once had a Sugden A21 at 23w into 8ohm and it was great. Now I also had the first version of that at 15w and it was not enough.
frugal-phile™
Joined 2001
The impedance curve may not drop below 8Ω but it is kinda ugly. No F1 or F2 for you. 45° phase angle at about 500 Hz. Remeber P=VA x cos(phase angle) = 0.707 x VA in this case.
dave
F5
yup , adequate with power also , same note as for M2 , regarding preamp
though , my sympathies are always at M2 side :D
Why does the F5 or M2 need a preamp? You mean if low efficiency speakers, or pretty much always? Just asking because I built the juma variation F5 and now curious if I have to build another thing :scratch2::D I've got plenty of volume with dac directly to F5. Sounds pretty great btw
