Search problem "GaN transistor"
I saw the thread
http://www.diyaudio.com/forums/powe...or-replacement-sic-rectifier.html#post5348261
and wanted to be informed of these semiconductors.
The search for "GaN transistor" in parentheses turns out with no result:
"Sorry - no matches. Please try some different terms. "
Search without parentheses is useless. But as you see in the thread title
the phrase was used in the forum. "GaN" alone will give no result either.
What is going on ? Thanks.
PS "SiC transistor" search works ..
In the maentime it works if you put the short phrase in " " and the error message
The following words are either very common, too long, or too short and were not
in your search : ..." does not appear in that case.
