Have a look here, should/might be interesting for you.
http://www.diyaudio.com/forums/soli...-mosfets-complementary-pairs.html#post3133236
I have used this seller on Ebay......6x Matched IRFP240 N-Ch POWER MOSFET 20A 200V 150W . VISHAY / SILICONIX | eBay
Have had results of Vgs within 0.001 - 0.003V
cheers
cheers
It's not difficult to get matches if they come from the same tubes.
Also, matching to .1v is generally pretty adequate. At PL we use .01V
only because it's easy to do.
np
Do you match pairs for each particular amplifier using that circuit's Vds?
I have looked a the eBay seller Punkydawgs. He uses 9V to characterize his matches. The F4 circuit that I am building uses the K170/J74 JFETs at about 14.4V Vds.
If a pair is matched at 9V Vds, that is no guarantee that they are a match at a higher Vds, correct?
The operating temperature inside the closed case will also make a difference. The jfets are very sensitive to the temperature. So, if you want to have a "closely" matched pairs (or quads) under your amp's operating condition, a temperature control jig is also needed.Do you match pairs for each particular amplifier using that circuit's Vds?
FWIW, in the F5X project, NicMac acquires hundreds (if not thousands) Toshiba jfets and matched them in NNNNPPPP under Patrick's (EUVL, the F5X designer) matching instructions. There were not too many yields, and each set cost a fortune but still good price for what they are!!! However, they are not perfect match (still good match) in a different operating condition (can be affected by many factors in the DIY world ). No prematch set will satisfy each diyer's creativity.
One thing for sure, a matched pair at 9V is going to be many times better than a random pair. Given these jfets (Toshiba and Linear) are close to impossible to buy in bulk to match ourselves, we probably will have to accept the general 9V matching practice to get the project going and be happy.
Exactly what was looking for but for high power mosfet like irfp140 etc
Plenty of things to be obsessed with,long before best N-P pairing.....
I have never bothered matching transistors in amplifiers.
So long as there are current sharing resistors in outputs things should be fine.
This helps. Thanks. Where is the definitive write-up for matching the K170/J74 pairs? I have downloaded the write up on PassDiy but it was not totally clear to me.The operating temperature inside the closed case will also make a difference. The jfets are very sensitive to the temperature. So, if you want to have a "closely" matched pairs (or quads) under your amp's operating condition, a temperature control jig is also needed.
I don't know much, but after years of reading posts here ( my original profile, lost somehow, would state 2005 for join date ) - I do know this to be true.
I mean matching the transconductance of the N and the P couple. Not the NN and PP matching
Irfp9140 has closer transconductance to the irfp240 than the irfp140
I have used IXTQ36N30P and IXTQ36P15P with great success. They seem a pretty decent match to me.
My original questions were rather simple,
is the 9140 more complementary to the 240 than the 9240 ?
is the 244 or 340 more complementary to the 9240 than the 240?
is the irf630 more complementary to the irf9530 than the irf530?
asking because I have to buy new mosfets for PASS amps (F4 F5 etc)
Does anybody have LTspice models for these fets to share?
- more complementary pairs than IRFP240/IRFP9240
