BTL mode
I go trough the datasheet of the TDA7492. If i understand you correct.
the chip is an BTL mode chip..... so the "BTL" Bridged tied Load " is implemented. so no jumper or other modifications are needed to switch this mode on.
  • TDa7492p_Datasheet.pdf
Features:
With 4 model GAIN parts, can auto work on different voltage
The use of high-speed SMT placement machine, over temperature reflow, the performance is very stable
Comes with super output short-circuit and over-temperature overload and prevent the impact of the switch machine
Specification:
Power supply: Single-voltage 10-26V DC
Maximum power: 2x50W / 8 Ohms
Mono BTL power: 100W / 4 Ohms
Size: 71 x 60 x 20 mm
Note:
When the speaker impedance is 4 ohms, the operating voltage must be less than 18V;
When the speaker impedance is 6 ohms, the operating voltage can not exceed 24V;
When the speaker impedance is 8 ohms, the working voltage can not exceed 26V.
The power not to reverse the polarity.
cheers guys. so in theory looking at the diagram I would say tie the speaker + to the right side terminal and the speaker - to the left side terminal. or am I wrong
This is the bridge mode.
Suppresses interference from mains.
Oh..Yes you are right......sorry my fault. Wrong Attachment.
Sorry
Google Image Result for https://m.eet.com/media/1179712/new_approaches_switched_mode_amplifiers_fig2.jpg
In pic i can see nothing. Diagram....? Can't See it
I found some pics from the other side of the PCB. In the middle there is the Power Connection. Vcc and Gnd
Left and right are the Speaker Connectors. Plus + to plus +....and Minus - to minus-
I was referring to the diagram you posted chermann. but here is the diagram for the amp.
so my question is if I want to use a single speaker or in mono mode, which terminals do I connect the speaker to as there are 4 terminals L+- and R +-
From the picture I would say that amp is already running in BTL mode ... the four output coils for two speaker connectors is a dead giveaway.
What you've got there is a nice little stereo amplifier ... hook it up and enjoy it.
The specs you showed appear to be gibberish, posted to impress you, not represent the product. Keep in mind that this stuff gets sold in pallet quantities and is often put online by people who wouldn't know an amplifier from a watermelon.
