Aleph 5, change of sound ?
After a few years, i wanted to change my bulky stereo A5 into a set of mono amps. The large stereo version was so heavy, i couldn't lift it.
Also it is not practical......
So i decided to start collecting stuff for making the mono chassis.
New heatsinking, new transformers, new capacitors, etc, etc.
But after a few listening hours i get the feeling, i'm missing the punch in the bass. I think the stereo chassis did it better.
Although i think the specs should be better, it sounds not better.... :crying:
Stereo version :
1 x 800 VA transformer
6 x 68000uF caps (3 per rail)
Low offset (after tweaking with R11 (221ohm))
1 x Heatsink(0,1K/W) (temperature was good, no burning hands...
Mono version :
1 x 600 VA transformer
4 x 68000uF caps (2 per rail)
again low offset
2 x Heatsink(0,2K/W) temperature was lower
I wired the 3 transistors with 14 AWG wire to the opposing heatsink.
That should be enough, right ?
I'm affraid that bending the legs of the output devices again might break them, so therefore i try to get help on the forum.
Maybe i made a mistake, don't know....
Anybody ideas about the change of sound ?
regards,
Nick
