TI to discontinue many ICs!
Updated op amp shootout.
Well, heck - thanks for the pointer! TI's website says the LME49710 has a 'LIFEBUY' status now, which is sorta sad IMHO. I've been designing this very nice amplifier into a device, and I'm not sure that the OPA1611, their suggested "invented at TI replacement" is not a step back.
Thanks for staying on top of things, and cheers!
I just wanted to order more LME49860 for my project (Bridged Buffered Opamp Amp - a journey), but now I saw that the price at Digikey had become $37 for each! It is still listed as active on TI's page, but obviously they don't really want to sell it anymore.
In searching for alternatives I found the LMP8672: LMP8672 Dual 40V Low Noise Precision Amplifiers | TI.com
I'm wondering if this is the same amplifier, just marketed differently? The specs look very similar, what do you think?
Would any of you op amp experts out there care to suggest a replacement for the LME49990AM I decided (unwisely) to use in my MM/MC pre-amp.
It was a beautiful amplifier, but there is really nothing equivalent anymore. The AD797 has similar noise characteristics, and also has extremely low distortion, but it is slightly finicky to stabilize.
The LME49720 / LM4562 has extremely low distortion, and is also pretty easy to stabilize, but it has a good bit more input voltage noise. However, I imagine that you could build a somewhat low gain, fast, but low noise front end amplifier and put the 4562 in the feedback loop and get something more suited to a MC cartridge. For MM, the noise of the LM4562 should be just fine.
The LT1028 and LT1115 also have noise characteristics that are similar to the 49990, so they should be examined as well. Best of luck!
