I am new to this forum although I am using a RPi HFB DAC since 2014 with openelec. I have upgraded to RPi 3 + BOSS DAC recently. I wanted to try Moode but making own image file from resources available does not seem to be.my cup of tea. May i know whether the upcoming RC1 version will be released in .Img format.
No img file will be distributed because of GPL. You have to build it yourself.I am new to this forum although I am using a RPi HFB DAC since 2014 with openelec. I have upgraded to RPi 3 + BOSS DAC recently. I wanted to try Moode but making own image file from resources available does not seem to be.my cup of tea. May i know whether the upcoming RC1 version will be released in .Img format.
That much is true, but it should be noted that the auto build (moosimbo.sh) developed by Koda59 and HeeBoo does make it a quite simple process - providing you read and follow the instructions to the letter!
This can be found in Summary at the bottom of the moodeaudio.org web page.
moOde is Free Open Source Software (FOSS) and I'm no longer distributing pre-made images. I may provide them in the future if I can fully automate the very time consuming GPL administrative tasks, otherwise you can build moOde using the manual Build Recipe or the Automated Image Builder. It requires some Linux skills but if you read the diyAudio moOde thread you will see that many novices have been successful. The manual Recipe is located in the directory below.
rel-stretch/other/build
The automated Image Builder can be downloaded at moodeaudio.org in the Support section.
If you wait a bit, a new Image Builder will be available at moodeaudio.org ahead of the GA release of moOde 4.0 (end of month). This Builder is based on the awesome work of Koda59 and HeeBoo and is easier to use and very robust 🙂
-Tim
In that case can you guide me more?
1. I install raspbian in sd card. Boot my pi from that.
2. Connect to Pi and login to Pi from my PC and execute the commands through putty in letter and spirit. And my Pi will boot in MoOde.
3. If the above two points are ok what is the utility of source code of version 4.0 beta 12 given in the download section of the same page. Is it to be ignored if I can successfully run moosimbo script?
Partha
I have already posted a query just now which is awaiting moderator's approval. But TIM in the above post has made the thing clear I think, if I use the automated image builder (moosimbo) I don't need the manual source code of the download section. Only thing is I need to boot my Pi with Raspbian once. Tim can you please confirm that I have understood correctly. One more thing, shall I install Raspbian Desktop version or Stretch Lite version?
Tim, thanks for your support. It seems i won't be able to keep patience till end of the month. Better i will do it in a couple of days and make myself conversant with the process which will be helpful once your new builder comes out. Thanks a lot.
Partha
Partha
Partha
1. Install Stretch-lite to your uSD card using Etcher or Win32diskimager.
2. Once installed, on your PC use Windows explorer to add a new empty file called SSH in the boot directory of Stretch lite. Eject SD card from PC
Install SD card in Pi, power on and allow to boot. Now you can ssh to Pi using Putty or similar. Usre : pi, Password: raspberry.
3. Download the image builder as described in Moodeaudio.org. Start the image builder. Build might take an hour or more depending on internet connections etc.
4. You can track the build using
ssh pi@moode "cat ~/mosbuild.log | grep 'COMPONENT\|STEP\| Compile \| END\| Error'"
User is now pi, password moodeaudio.
5. When complete you will see the END message. now you can access Moode via your browser.
Good Luck
Ian
Just to confirm what Ian has written, I carried out the exact steps this afternoon and now have Beta12 up and running. Wish I had read his post first, took me ages to work out were to put the SSH file and to get Putty working on my pc.
Has anyone switched from Pi 2 to Pi 3, using USB 3.0 flash drive for media storage/
USB 150Mb to 300Mb Wifi adapter?
I just want to know if there is improvement in performance or sound quality, significant
or just marginal.
or just marginal.
Is there an FAQ and guide to start from scratch?
1. Use Win32diskimager, copy kernal to uSD
2. Install Wifi Adapter/USB Media Storage
3. At prompt, run Moode Download
4. Reset
5. Launch Web Browser/Config DAC hardware/Play Media Sourcd
Step 3, are there more details involved to get it running?
4. Reset
4. Reset
In preparation of the general release of v4.0 I did a build for one of my 3 RPi's. Using HeeBoo's post and the info scattered here and there, I documented what I did (see attached below). Keep in mind this was on a PC running Windows 10 Home. Ymmv.
hth.
Yes. Read the guide by BackinBlack on the previous page.
Hi Everyone.
Recently installed Moode and have been enjoying it so far. My setup is a RPi + Hifiberry Digi Plus + Beresford Bushman MKii DAC + Cambridge Audio Integrated Amp + KEF Q350. My TV is connected to my DAC through TosLink and Pi through SPDIF and the DAC has the ability to switch inputs based on what input is on. The only problem is that when switch I off my TV and want to listen to music through the Pi, the inputs don't switch automatically and I have to go and change the inputs manually. Is it because the Pi is always on and keeps sending some empty signal to the DAC to make it think that it is on even though there is no music. Does anybody in the forum have a similar problem (a very very first world one though). The reason why I ask is am lazy sometimes to go change the inputs and that prevents me from listening to music as much as I want too.
FYI Thanks Tim for the excellent software. I have been using RPi from the initial days from simply running MPD and as a community we have come a long way.
Hi @terasain,
:-0 setup
If none of the audio renderers are playing then there should not be any samples being sent to the audio device. Are u just using MPD?
Btw, nice speaks. I have set of vintage 1980's KEF Q60's that still sound great, especially with an HSU Sub 🙂
-Tim
:-0 setup
-Tim
Does any one know about this BDP-Pi Digital Player - Bryston. Its basically a RPi + HifiBerry Digi+ with a screen attached. Curious to know what software they are running. They are charging a preposterous 1250$ when the bill of materials is surely under 200$.
hth.
I'm running Windows 7
Awesome! Thank you!🙂
hi guys,
sorry but i am a complete noob at this installation, i did manage to get volumio to work but cant understand how to install the moode audio.
i read a few time what a few users have written but i cant seem to understand it. is there a simpler way to instal moode audio.
- PC Based
- Moode Audio Player for Raspberry Pi
