Zion, a ready made Phono Stage by the Paradise team
RIAA plug-board
Progress report 🙂 Here is the schema and PCB for the RIAA components, please comment on those. The board size is 40x95mm (and I really would not like to change that 🙂). All capacitors have an area of 10x34mm and 2 arrays of holes, one line-array at 2.5mm intervals and one line-array of 2.54mm intervals. The line have each 2 x 6 holes (for each line-array). The capacitors and resistors can be surface mount.
Not really 🙂, but nowadays it is not to expensive to have them made by a specialized PCB producer, and the bonus is a very high quality finish. As soon as you need some volume, having them made will(can) be cheaper then making them yourself (that is true also for 2 layer boards).
Well, the good things is that it does help create group interests and group buys, which at least goes against this individualistic world we live in. 😉
Progress report (I know it is developing slow)
Sorry to be (again) a bit slow, but on one of my professional projects I have a major mile-stone coming up (could be life changing 🙂). Any way this lows everything down.
The picture attached shows the high-impedance-buffer followed by the line-driver stage. The line-driven can be configured for balanced or unbalanced signal delivery. It also supports a volume control.
And here are the resistor and capacitor values for the parts around UPb and UNb, one set of values for 10dB gain and one set of values for 20dB gain.
What total gain alternatives will there be with the +10 and +20dB settings? I would be fine with 55dB gain because my line-stage stage have balanced input which bypasses 2:1 input transformers for SE-BAL conversion. So there i already have enough gain 🙂
Progress (again) 🙂
This is the RIAA-components board. It accommodates multiple capacitors and resistors. The holes for the capacitors are in rows (row distance 5mm) and the holes have a center-to-center distance of 1.25mm. Besides through-hole components the board accommodates smd parts.
The board size is 60 x 40mm, the areas for the capacitors are 22 x 13mm and 22 x 17.5mm. That should be ample space for several capacitors.
Any comments, please let me know 🙂
