QSC RMX 850 Power Supply Caps
It is something I've always thought about: Replacing the original caps for ones with higher capacity; I can't understand why QSC uses supply low capacitance caps. But I think it may improve amplifier performance if best caps are added. Yesterday I uploaded a RMX 1450 clon here in the forum, look for it at Solid amp thread. I put 6800uf in the Power supply. It sounds delightful.
The thread is called Common Ground Colector.
I did to it nothing else. No problem if you want to put capacitors with higher capacitance. In my QSC RMX project I used Four 6800uF caps (two per supply rail) instead of 3300uF used in the original amp so replace them. No fear.
