hi all,
I'm a 1st time SSE builder and I hope you can help me shed the light on choosing the right cathode resistor R17 and R27 for different tube types.
I have read several threads in this forum about cathode resistor and also trying to build a switch to select different resistors for different tubes like member Russ "rkinze".
I look over George's tube& application table.
"choose a cathode resistor value for a given amount of tube dissipation" Tubes and Applications | Tubelab
My build include
Power Transformer: Edcor XPWR059
Output Transformer: Edcor CXSE25-8-5K
Output tube: KT88 genalex gold lion & EL34 - Electro Harmonix
My build's B+ voltage is around 450V. Looking at EL34 & KT88 data sheet and George's table for KT88, EL34 450V, I still don't know which value of Rk to use for these tubes.
Can someone show me what values of dissipation on the 2 data sheet I need to look at and compare with George's table ? I check every value of dissipation in the 2 spec sheet but they are not matching with George' Pwr out values
EL34 Electro harmonix's data sheet:
https://www.newsensor.com/pdf/electro-harmonix/el34eh.pdf
KT88 - Gold lion data shee
http://www.jacmusic.com/KT88/kt88_spec_sheet.pdf
I really appreciate your inputs.
thanks,
Tom
My build include
thanks,
Tom
Yes, same as Treybal I've used 560R 10W with a similar B+ 440V. No problems.
To run the EL34 at a little less dissipation you could use a 680R-10W resistor and then install a switch to parallel a 2.2K-5W when you run the KT88. Effectively ~520 ohms. Use a wirewound for both.
To answer your question, the values you look at on the data sheet are Plate Dissipation (Pa) and Screen (grid 2) Dissipation. If you are running the tubes as triodes, since the plate and G2 are tied together, you can add the plate and screen dissipation.
If you already have the metal oxide resistors then use them. I've read that metal oxide are noisier than wirewound or metal film, but I'm not sure it will matter in this case. Someone else may want to comment. I don't have any personal experience using metal oxide in this application.
You said "resistors", does that mean you are going to use more than one to make the 2.2k? When using the KT88, the 2.2k in parallel with the 680R is going to need to dissipate close to 1 watt.
Thanks Scott. In this case, I'll stay with wirewound all the way. I didn't know metal oxide is noisier. I have not bought all the resistors for this just yet. I only use 1 resistor in // with 680R. I thought putting resistor in // will increase power. So if 680R is already 10W, we only need 3W or 5W of the other resistor right ?
Thanks,
Tom
Thanks,
Tom
Hi Tom,
If the resistors were both the same value then yes, each one would dissipate half the wattage. They both have the same voltage across them so if you do the math you'll see. P=E^2/R. I would use a 5W 2.2k. For anode and cathode resistors I like to take the actual wattage dissipation and multiply by 4.
Thank you Scott. Really appreciate your inputs and explanation!
Tom
Tom
Hi Tom,
- More Vendors...
- Tubelab
- Tubelab SSE - Cathode resistor understanding
