Hi, its been a while last time i posted on this forum....
I do have this Sony GX69Es integrated amplifier that i like a lot, mated to a Technics Sl2000 turntable on a fresh needle setup.
i always found its sound to be "dry" no matter what.
i was wondering if any experienced electronics guru would dare to look at the schematic of the riaa preamp itself and pinpoints potential "improvements" to give more hump to this set-up.
yes i am thinking about altering the riaa curve or whatever that could improve its sound rendering.
fwiw the whole amp got a capacitor refresh with some nichicon fg and elna silmics (i know there are other choices, better than nothing there), no noticeable improvements once done.
thanks.
thanks.
Yes. We are modifying the values of the RIAA equalization components.
In this case, by increasing from 560k to 680k, you increase the low frequencies and decrease the average lows a bit, which are what give the sensation of "dry blow".
In the forum there are people who know a lot about the subject (AndrewT, Calvin, RJM, Vulejov, etc)
so you mean by changing the 560k to a 680k makes a difference in the low end response ?
A better value for C505 seems to be 1.57nF, so add a parallel 68pF across it.
All the other component values (including R526) are close enough as-is.
I have simulated replacing the capacitor C505 with value of 1.57nF.
It is closer to a flat response. But what you want is to decrease the "dry" sound and give more warmth to the low frequencies.
You choose.
I'll tell you, I have a Marantz PM6006 integrated amplifier with a phono preamp with excellent sound, but I'm using an external phono preamp (Kit VSPS 400 from RJM) connected to the auxiliary.
Result: superior sound; more details; broader soud stage.
I repeat your choices from changing a resistor, a capacitor or using a good external phono pre.
I suspect he should just buy a new and better design external RIAA preamp.
fow now i want to keep the modifications as simple as possible. i will try to change the resistor and maybe the cap too and will let you know how it goes.
thanks a lot guys !!
Increase R523 to 82 kohm; assuming an ideal op-amp, right now the input shunt resistance at audio frequencies is (R523 // R524) + R501 ~= 32.3 kohm, while all normal MM cartridges are designed for 47 kohm. This makes a difference for the treble, not for the bass.
i made a search and didnt realy found anything about the dry blow sensation.
id like to read read more about it, if you could point me to some threads about it i would appreciate
regards,
"Hi, its been a while last time i posted on this forum....
i always found its sound to be "dry" no matter what."
You said it. It sounds "dry." This is a result of the fact that the frequencies between 150 and 350 Hz are stronger.
If you want it to sound with a serious less "dry", more pleasant you have to decrease those frequencies slightly and accentuate the frequencies from 20 to 50 hz.
With regard to the RIAA curve "perfectly flat" is debatable, since the recording engineers themselves alter it. Listen to a record of a same disc and the label of another label and you will notice the differences in sound. It also depends on the charge of the cartridge, which in an integrated amplifier can not be varied (load impedance and capacitance).
The important thing is that you agree and that you like what you hear.
There are famous brands such as Rotel, Marantz that slightly emphasize the frequencies between 20 and 50 hours, as well as DIY kits that also do it (Rod Elliott Kit, VSPS400).
i have a 10 bands equalizer to make me agree to what i listen too (!), but overall i am disapointed of my turntable set-up.
so i will try the mods today but rather than juste stick with the given values i will try some combinations with potentiometers and switches to listen before/after mods.
thanks.
thanks.
Be careful with the potentiometers. They can cause noise. The phono preamplifier is very sensitive.
Phono RIAA
I would not have blamed Sonny's pre-amplifier on a "dry sound".
I've done this pre-amplifier for me, which definitely gave amazing results when it was based on low-noise transistors. In fact sound quality of the time with today's technology.
you can see pictures in this link:
HIFI RIAA Discrete Low Noise Transistors Stereo MM Phono Preamp Board Single 12V | eBay
i would like to revive this thread as i builded on a veroboard the SONY version (first schematic) with the suggested modifications. Any other concerns i should look for about this particular schematic ? i want to build "around" this method. thanks for any suggestions and helps.
do you think it will increase the treble or decrease it ?
i dont masterise yet the effect of the load on MM cartridge.
thanks.
You should get more treble with 47 kohm than with 32.3 kohm.
thanks
i made my prototype with dip switches so i can change the load on the fly, the cap load also with 3x 100pf steps
change is very subtle i would say. overall is sounds less dry with 300pf load and "real" 47k. feels more warmth
can anyone explain me the use of C503 (33uf/16v) in the negative leg of the feedback network. i see many designs using this method but more larger values 47-100uf.
thanks.
thanks.
It makes sure that the op-amp doesn't amplify its own offset 608 times (which would cost headroom) and it reduces the amplification for very deep subsonic rumble. The cut-off frequency caused by this capacitor is 1/(2 pi C503 R525), which boils down to about 5 Hz.
- Analogue Source
- RIAA preamp into my sony gx69es
