Googling snubbed RC rectifier circuits and not really finding relevant information (I think!)
Does each diode need an RC applied, or just on the DC output?
Sorry I hadn’t described that very well, it’s the dc side, yes.
This shows a setup where those parts are used in conjunction with others on a board, but I have had good results using them as close to the diodes as possible. I had done this with 2” leads on my first DAC, and recently had it apart, made changes to place the components directly onto the pins of the diodes, under the board, and it works much better.
http://www.diyaudio.com/forums/atta...gainclone-power-supply-ii-snubberized_psu-pdf
Per Anders designed my PSU... I'll have to look at the schematic, but it might already be implemented on it.
Thanks for the link.
Thanks... Yeah, it's a gem.That’s a pretty healthy power supply, should have a nice DAC when you get it together.
Merry Christmas!
