Hi all,
My home electrical installation does not have grounding, its bi-phase 220V (127V + 127V). What kind of grounding should my tube amp have?
Do you mean say the condo transformer is grounded? Its a 225KVA, input in 13800V output is RTF 127V x3.
Apparently, in Brazil, there are many variations used, so I would consult a local electrician,
for safety. Even if you have three phase power, some systems do have the center grounded,
unless it's a delta system, where there is no center to tap.
Here it's 27kv6 to 208 Three phase. 120V phase to neutral, 208 phase to phase.
Where? I doubt any residence in Canada is like that. AFAIK it's all single phase 240V in residential areas.
Nope. Most appartment buildings in at least the Toronto area of any appreciable size (my building has almost 300 units) are supplied with 27.6kV to 208 three phase/120V neutral. They even have special stoves that are designed for 208V instead of 240V. I have one.
EDIT: My building is also heated electrically.
EDIT2: no stand alone homes are powered like this, they all receive 240V split phase.
Connecting all device chassies together will cut all leakage currents, can be done with grounded ( 3 prong) cables connected to a 3-prong distribution connector.Hi all,
If this distribution connect is addition can be grounded is a plus. You might have a suitable ground around : possible sources :
water filled oom heaters supplied from a central source,
cable-tv screen,
if living on ground floor: a steel or metal pole stuck at least 1 meter down
tap water tube, often made by copper and well grounded
etc
but don't use any lightning arrestors !!
But as you electrical system is symmetrical around ground zero, chances are that your connected chassies are very close to zero. Interconnection of all devices will make the most effect.
In North America that 0V (neutral) is connect to ground (Earth).Hi all,
You could use an isolating transformer for the 127-0-127 wiring, like some 600-1000VA toroid, connect it any way you want. IMO it also gives a bit of filtering from power line's noise.
For years I lived with split phase, no ground in France. There isn't much you can do if you can't make your own ground. You just have to live without, like our ancestors did. 🙂
I already used a 220V-120V 4.5kg stepdown Toroidal to the CD player for some time, when I removed it the sound quality increased instantly.You could use an isolating transformer for the 127-0-127 wiring, like some 600-1000VA toroid, connect it any way you want. IMO it also gives a bit of filtering from power line's noise.
Gentlebeings--
We have been through this before. This is NOT the power systems used in the US/Can, or the UK.... many systems are possible and Brazil is known to use several of them.
Normally the metal shell of your clothes washer, and metal switch-covers, returns to a Protective Earth from the power company. Do you have that?
...does not have grounding, its bi-phase 220V (127V + 127V).....
Currently buildings have 3 pins (phase neutral ground to 127V or phase phase ground to 220V), but my condo is not this time.Connecting all device chassies together will cut all leakage currents, can be done with grounded ( 3 prong) cables connected to a 3-prong distribution connector. <snip>
The electric shower tap gave shock, then I solved the problem with a PVC pipe from shower to wall.
Metal water pipe has served me well....
...The electric shower tap gave shock, then I solved the problem with a PVC pipe from shower to wall.
He's getting shocked *by the water pipe*!
Connecting hi-fi chassis to this piping may be VERY DANGEROUS.
I wonder if you have a breakdown in the insulation of the electric shower.
I really think you should consult Expert Local Advice, not some hi-fi geeks 3000+ miles away who have never seen an electric supply such as yours.
I would agree that it would be best to check with a local expert, but would not be surprised if the answer was "that's what it is". 2 prong 240V was normal not too long ago. My grandparents home in Italy is still wired that way, albeit uninhabited and eligible for free upgrade from the utility.
So if you have to make do with what you have, you need to look at things like GFCI and/or double insulated design techniques for peace of mind with your DIY projects.
All power outlets in my apto have only 2 phases wires.Gentlebeings--
Afew years ago I was using an aluminium window as ground as it near the system.
YOU RIGHT Here the situation is very bad, carpenters, locksmiths and electricians can not spell the alphabet.I would agree that it would be best to check with a local expert, but would not be surprised if the answer was "that's what it is". 2 prong 240V was normal not too long ago. My grandparents home in Italy is still wired that way, albeit uninhabited and eligible for free upgrade from the utility.
Usually are unreliable people, especially if the client does not know the subject.
So Returning to the original question:
What grounding type/schema my tube amp should have?
Having groundless outlets on home.
Thanks for help🙂
It seems that the two different common grounding systems are getting co-mingled again.
a] The Safety Ground/Protective Earth system. It's main task is to trip a circuit breaker in the event of a ground fault (short circuit). Most large exposed metal objects should be bonded (permanent connect) to this system.
b] The connection to Planet Earth. It's there for safety 1] during thunderstorms 2] high voltage failures (like if a high voltage wire falls on a low voltage wire) 3] to keep the Neutral at about the same potential as the swimming pool or damp floor.
Note the the connection to Planet Earth has nothing to do with day-to-day AC power quality.
It is not one of these kind of showers by any chance. Shocks are common from them. The Latin American Suicide Shower - Argentina - WorldNomads.com
- General Interest
- Everything Else
- Home with NO Ground in Electrical Installation
