I am looking for some 8-pin octal tube sockets which allows mounting the tube horizontal above the PCB rather than standing vertically on it.
So I was wondering, do such tube sockets exist? Something with a bracket for 90 deg mounting, or maybe with a small PCB that mounts upright on the main PCB?
Not a tube guy at all so don't know really where to look, or whether this exists at all.
Jan
Jan
I have never seen such a thing in my 70 years, but that doesn;t mean they don't exist.
However, in pro audio there are numerous examples of horizontal tube mounting. One rack space tube preamps for example. Peavey has any number of tube amps with horizontal preamp and power amp tubes. Many examples
But in every case, the sockets are mounted to a sub-board, a smaller pc board. that board is then connected to the main board by a ribbon cable or a direct linear connector.
I would be looking to make a small socket board to mount upright on the main.
The Peavey Rockmaster Preamp is a good example, and the schematic file shows the board layout with traces, but it is too large a file for this forum. The company would send it to you upon request though. it is a one space with four 12AX7s.
Hi Enzo,
Thanks for the info. In the mean time, someone pointed me at this:
http://www.apexjr.com/images/RtAngle9pin.jpg
But that still requires p-p wiring. Maybe a sub pcb is the way to go. Using angled connectors I could make them plug-in, if it is mechanically stable enough.
Jan
Jan
Why not mount the sockets on a right angle plate and then hard wire it.
Valves work in any orientation.
As I said, I want to run it horizontal. It's the ease of mounting/plugging in I am looking for a good solution.
Jan
Jan
Here's an example:
Tube Amps Mounting Bracket W/ Vacuum Tube Socket Base For Marantz 7 McIntosh C22 | eBay
Should be easy to diy.
Yes, that would work. If need be I will whip something like that up. I was hoping to find something elegant that can be easily plugged into a PCB.
Jan
Jan
Hi Jan; If a power tube or regulator application is involved I would be cautious. Depending on stress levels, or whether or not grid current is involved in it's operation, sagging of the grid or filament could result in tube failure. Tube spec sheets normally say if none vertical operation is OK, but application matters as well .My 2 cents. John
Exactly! I knew someone would have done it!
Thanks Juergen,
Jan
Yes, agreed. My app would be a vertical PCB so the tube, flat on the board, would actually stand upright. But good point, thanks,
Jan
Old thread I know......
Anyone know where I can get the sockets like the ones from ApexJr as above ?
Andy
Andy
Yes, that's true. Tube manufacturers used to give the advice, though, that tubes have to be arranged in a manner that the grid supporting rods (i.e. the long axis of the internal structure's cross section) are perpendicular when the tube is mounted horizontally.
Best regards!
Hi again,
I am really looking for sockets as per below.
Any ideas?
Andy
Any ideas?
Andy
- Design & Build
- Parts
- 90 degrees mount tube sockets
