Balanced diy tube preamp
Hi.
I need a balanced diy tube preamp for my soundsystem. 2 channel stereo line XLR in/output. "Audiophile" grade. Whatever that is lol. It should sound just very good. No sloppy bass, etc.
It should produce deep clean precise bass and have a warm like sound in mids/highs.
I found out about the aikido pre amp but I think it won't sound exactly warm and then again the schematic I found has no balanced in and outputs.
Any recommendations? Hints?
Much appreciated.
Or just add balanced in and outputs to the aikido but I don`t know exactly how?
I run a SE😛P linestage to drive the XLR input on my Rane AC23B. It is a LTP of EL84 triodes, with B+ near 500V and 15k Ohm loads. The only mod I am considering is dropping the loads to 10k, and bumping the idle current by 25-30%.
Depending on how much gain is needed, a 12B4 can be used, or EL86 triodes.
There is another option I have under consideration, and that is an amplifier triode, feeding a stout concertina....but since the current one works quite well, I am not feeling the need to change it just yet...🙂
The EL84 LTP rig is running 7.5 uF X386, 330 VAC polypropylene motor runs for output coupling. It is a little hard on the input OP amp...🙂
cheers,
Douglas
cheers,
Douglas
I like the simple approach.
Any schematic?
Which tubes should I use?
I'd say the 6FQ7, for 20dB gain. Here's JB's info.
"A 12AX7 input tube will yield a gain close to 50 (mu/2);
a 6FQ7 (6CG7) input tube will yield a gain near 10, which would be excellent for a line stage amplifier;
the 6DJ8 or 6H30 in the output stage would deliver a low output impedance that could drive capacitance-laden cables.
In other words, the list of possible tubes is a long one: 6AQ8, 6BC8, 6BK7, 6BQ7, 6BS8, 6DJ8, 6FQ7, 6GC7, 6H30, 6KN8, 6N1P, 12AT7, 12AU7, 12AV7, 12AX7, 12BH7, 12DJ8, 12FQ7, 5751, 5963, 5965, 6072, 6922, E188CC, ECC88, ECC99... The only stipulations are that the two triodes within the envelope be similar and that the tube conforms to the 9A or 9AJ base pin-out. Sadly, the 12B4 and 5687 cannot be used with this PCB."
