Ultrasonic cleaner owners, how to drain the tanks without tipping the water out?
As the title suggests
My cleaner has no drain and the instructions say not to 'tip' the water out so I am curious if anyone has found anything that can suck the water out of the tank (leaving me to sponge dry the leftover)?
Or will it be a case of gloves on and use a pint glass to empty it that way?
The ultrasonic cleaner I use, made by Louis Steele of Vibrato, LLC, doesn’t have a drain either. If you want a fast way to drain the tank I’ve found a 12volt pump works well for me. A siphon is much simpler and cheaper. 3/“8 to 1/2” ID tubing should drain yours pretty quickly. I just had the pump on hand when purchasing the Vibrato ultrasonic cleaner. Best O Luck!
Yes mine also :santa2:
