Power supply options for tube preamp
For most of my audio projects I’ve been working with linear supplies. Convenient, easy to calculate and regulate. Never cheap or flexible though.
For a new preamp project I’m looking for a power supply that is able to deliver 20 mA at 420V to 5 12ax7’s. Two triodes will be cathode followers with the cathodes at 180 V. The heaters probably need to be elevated. The best transformer I could find in The Netherlands is a Hammond 369bx. 300 Vct and enough heater current. Antek is much cheaper, but shipping is around 40 bucks.
So I started looking for cheaper options. Found some China made dc-dc converters capable of 450V and looked at some offerings of LT (lt3757 as flyback controller). I could drive them of a 12 V transformer, maybe regulated. Problem is: how do I elevate the heaters in that case? Not possible I think. I could use a separate fly back converter for the heaters, but then which one and how do I regulate the output of the 12 V converter while floating?
All in all a linear supply looks like a much easier option, but maybe you guys see other options I just totally miss?
I use these... DC-AC Converter 12V to 110V 200V 220V 280V 150W Inverter Boost Board Transformer | eBay
For 420V use the 220V AC output and a voltage doubler using 10u-22u caps and HER208 (or equivelent) for the diodes. The output is isolated from the input, and you should still be able to elevate the heaters. I power it from a 12V SMPS but you could use a linear 12V supply. You could also use 2 SMPS 12V supplies, one for the heaters, and one for the boost converter.
A pair of these would work: 6A-8A Unit For 12V 100W Switching Power Supply Board AC-DC Circuit Module | eBay
How hard do you want to play? Google "Current Fed Buck Converter". For example...
Not that hard haha. However, you are correct. This is perhaps the way to go when using one controller. But why not use two, e.g. EC3843's. One for HV, one for LV. There are loads of information to be found on the PWM controllers, not so much for the UC3827. I mean, I can read app notes and data sheets, but I'm not an EE. Working with a UC3827 probably requires a bit more than my basic SMPS knowledge.
I always use 2 cheap transformers back to back.
First transformer drops to 12 VAC for heaters then 12 VAC is stepped back up using a 18:240 volts transformer to get 160VAC for B+.
Use transformers to suit the voltages you need.
12V 30 VA into reversed 6V 15VA would do the job quite well. Buying new trannies (toroids) would probably set me back 50 to 55 Euros ex. shipping though. Will have to see what I've got lying around in the house.
EDIT: Got a 2x12V 50VA toroid around!
Still I wonder, where are the people that actually build a switching power supply for tube amps. Should be doable right? Würth offers some nice offline flyback transformers with a HV winding. 90-265 VAC to 285 V @ 70 kHz for example.
Yes... Not for the faint hearted. I would not suggest you try to implement an off-line power supply using this method but it might fall into your comfort zone if you consider using a 50Hz lump of iron to give you an isolated 15V supply with which to feed the chip.
http://www.farnell.com/datasheets/312001.pdf
http://citeseerx.ist.psu.edu/viewdo...65A63A4?doi=10.1.1.362.4613&rep=rep1&type=pdf
Second link is to SLUP117.pdf which TI do not appear to wish to give you unless you create an account with them. Unfortunately it is a bit overboard in that it goes into a great level of detail for most available topologies before settling on the UC3827. Then it still tries too hard...
If you have basic SMPS knowledge, you mention the peak current mode UC3843, then getting your head around the UC3827 should not cause too much stress. Using a lump of iron to supply things simplifies your feedback, no need for opto-couplers or similar.
Once you get the idea behind average current mode control and slope matching then design of the internal current loop and external voltage loop is a veritable pleasure. None of this slope compensation to avoid subharmonic oscillation as with peak current mode control.... not strictly true because you still need it for a stable peak current limit.
If you want I can slap together an idealised LTSPice model of the beast so you can have a practice. How many 6V3 Heater Supplies do you need and at what current? How many High Voltage Supplies do you need and at what voltages and currents?
I can take you through the compensation of the thing and you might be pleasantly at the level of performance that should be possible. <50uS[20uS] response times to step levels in load and other nice numbers.
Biggest fear would be that you probably should not knock one up on a bit of Vero Board. It might work but a PCB is recommended. Depends on your resources.
Iron to a dc-dc converter was my first idea actually. Some nice converters on fleabay. 12V 24V to DC 200-450V 70W High Voltage Boost Converter Step Up converter New | eBay
Good for up to 40W continuously, although I have no idea what the resulting dc looks like. I also don't know if different filtering with an additional LC would improve matters if needed. It looks like a flyback converter, so diode -> C.
Then again, how can I elevate the preceding 12V supply without affecting the DC-Dc converter? Can that even be done?
Now if I could find me a 12V to 12V isolated DC converter, the problem would be solved. Power the whole thing - separate DC-DC converters for LV and HV that is - with the 12V toroid I was mentioning earlier and elevate the output of the 12V converter via a divider form the HV. Done.
Or power two offline flyback converters and use off the shelf Würth transformers. Will post a schematic next, to clarify.
I'm just looking for a single 12.6V @ 750ma heater supply. Or 6.3V but double the current. I'm not sure how much current the tubes draw when cold. Cold resistance is 14 Ohms for 12.6V.
It would be great if you could make an idealised model, but please remember that it might just be for educational purposes.
I use vero just for low frequency setups and even then I almost never use it. I can build single sided photo's, although i generally prefer to outsource for more permanent setups/work. For small boards I send my stuff to OSHpark for example.
450 V with an LT1245 offline. At least it works in sim
I've used these. They are isolated, however they are adjustable which causes instabilities and oscillation if used with a choke input/crappy load.
I have used:
DC-DC 8-32V to 45-390V Step Up Power Supply Module High Voltage ZVS Boost Module | eBay
Not isolated, single ended design. I use one for powering a phono stage. More stable than the above.
I prefer this design. It's isolated. I use them with a voltage doubler on the AC output to get 420V.
MINI DC-AC Inverter 12V to 18V220V/380V 500W Boost Step UP Power Module New Hot | eBay
I use these for power amplifiers. I'm using one to power a PP 6550 Amp. Runs with a 10 - 15 degree rise at 150W output.
Take an AC to 12V converter that can handle your preamp's total power consumption. Tweak it to get 12.6 Vdc and feed the tubes' heaters and a DC to DC converter with isolated output for HV supply. Elevate your 12.6 Vdc by means of a voltage divider at the HV side. That's all. I can't see any problems with this, given that the HV converter is isolated.
Best regards!
What got me confused is how feedback from the HV supply would work. The output is isolated from a floating input via a fly back transformer. But the feedback path might or might not be isolated (if there is any feedback at all). I guess I will have to see how the feedback is done on an actual supply.
Apologies for the delay. Education is good. I'm getting some as I try to get the beast to work whilst dealing with competing issues.
I've assumed 1 X 420V@ 50mA and 2 X 12.6V @ 750mA. About 40W. I have also assumed that you might use a Laptop brick. You can get 70W ones with 19V out and they are cheap.
That takes care of your mains isolation but you should still be concerned about safety in respect of your 420V.
The following #CODE is the LTSpice model. Save as an .asc file and LTSpice should load it and let you poke about and play. Again this is not final but a closest best and possibly realisable guess.
Pictures are circuit, circuit in regulation, circuit with a 20mA/50mA load transient on the 420V rail and start up as things come into regulation.
There are reasons why it behaves the way it does and other than a load of other headaches some anomalous behaviour that could need chasing down.
I'll try some more words later.
Code:
Version 4
SHEET 1 3248 1352
WIRE 1664 -224 1232 -224
WIRE 144 -160 16 -160
WIRE 256 -160 224 -160
WIRE 352 -160 256 -160
WIRE 560 -160 432 -160
WIRE 672 -160 560 -160
WIRE 1056 -160 976 -160
WIRE 1184 -160 1120 -160
WIRE 1232 -160 1232 -224
WIRE 1232 -160 1184 -160
WIRE 1264 -160 1232 -160
WIRE 1376 -160 1344 -160
WIRE 1504 -160 1376 -160
WIRE 1632 -160 1504 -160
WIRE 1664 -160 1632 -160
WIRE 1856 -160 1776 -160
WIRE 1984 -160 1920 -160
WIRE 2032 -160 1984 -160
WIRE 2064 -160 2032 -160
WIRE 2176 -160 2144 -160
WIRE 2304 -160 2176 -160
WIRE 2336 -160 2304 -160
WIRE 2560 -160 2480 -160
WIRE 2688 -160 2624 -160
WIRE 2736 -160 2688 -160
WIRE 2768 -160 2736 -160
WIRE 2880 -160 2848 -160
WIRE 3008 -160 2880 -160
WIRE 3040 -160 3008 -160
WIRE 160 -80 160 -112
WIRE 160 -80 128 -80
WIRE 208 -80 208 -112
WIRE 976 -80 976 -160
WIRE 1056 -80 976 -80
WIRE 1152 -80 1120 -80
WIRE 1776 -80 1776 -160
WIRE 1856 -80 1776 -80
WIRE 1952 -80 1920 -80
WIRE 2480 -80 2480 -160
WIRE 2560 -80 2480 -80
WIRE 2656 -80 2624 -80
WIRE 560 -48 560 -160
WIRE 672 -48 672 -160
WIRE 976 -48 976 -80
WIRE 1232 -48 1232 -160
WIRE 1776 -48 1776 -80
WIRE 2032 -48 2032 -160
WIRE 2480 -48 2480 -80
WIRE 2736 -48 2736 -160
WIRE 1376 -32 1376 -160
WIRE 1504 -32 1504 -160
WIRE 2176 -32 2176 -160
WIRE 2880 -32 2880 -160
WIRE 16 48 16 -160
WIRE 560 64 560 32
WIRE 560 64 480 64
WIRE 672 64 672 32
WIRE 752 64 672 64
WIRE 976 64 976 32
WIRE 1056 64 976 64
WIRE 1152 64 1152 -80
WIRE 1152 64 1120 64
WIRE 1776 64 1776 32
WIRE 1856 64 1776 64
WIRE 1952 64 1952 -80
WIRE 1952 64 1920 64
WIRE 2480 64 2480 32
WIRE 2560 64 2480 64
WIRE 2656 64 2656 -80
WIRE 2656 64 2624 64
WIRE 256 128 256 -160
WIRE 480 128 480 64
WIRE 560 128 560 64
WIRE 672 128 672 64
WIRE 752 128 752 64
WIRE 432 144 400 144
WIRE 832 144 800 144
WIRE 976 144 976 64
WIRE 1056 144 976 144
WIRE 1184 144 1184 -160
WIRE 1184 144 1120 144
WIRE 1232 144 1232 16
WIRE 1504 144 1504 32
WIRE 1632 144 1632 -160
WIRE 1776 144 1776 64
WIRE 1856 144 1776 144
WIRE 1984 144 1984 -160
WIRE 1984 144 1920 144
WIRE 2032 144 2032 16
WIRE 2304 144 2304 -160
WIRE 2480 144 2480 64
WIRE 2560 144 2480 144
WIRE 2688 144 2688 -160
WIRE 2688 144 2624 144
WIRE 2736 144 2736 16
WIRE 3008 144 3008 -160
WIRE 16 256 16 128
WIRE 256 256 256 192
WIRE 256 256 16 256
WIRE 320 256 256 256
WIRE 432 256 432 192
WIRE 432 256 400 256
WIRE 480 256 480 208
WIRE 480 256 432 256
WIRE 560 256 560 192
WIRE 560 256 480 256
WIRE 672 256 672 192
WIRE 672 256 560 256
WIRE 752 256 752 208
WIRE 752 256 672 256
WIRE 800 256 800 192
WIRE 800 256 752 256
WIRE 1152 256 1152 64
WIRE 1152 256 800 256
WIRE 1232 256 1232 224
WIRE 1232 256 1152 256
WIRE 1376 256 1376 32
WIRE 1376 256 1232 256
WIRE 1504 256 1504 224
WIRE 1504 256 1376 256
WIRE 1632 256 1632 224
WIRE 1632 256 1504 256
WIRE 1952 256 1952 64
WIRE 1952 256 1632 256
WIRE 2032 256 2032 224
WIRE 2032 256 1952 256
WIRE 2176 256 2176 32
WIRE 2176 256 2032 256
WIRE 2304 256 2304 224
WIRE 2304 256 2176 256
WIRE 2656 256 2656 64
WIRE 2656 256 2304 256
WIRE 2736 256 2736 224
WIRE 2736 256 2656 256
WIRE 2880 256 2880 32
WIRE 2880 256 2736 256
WIRE 3008 256 3008 224
WIRE 3008 256 2880 256
WIRE 16 288 16 256
WIRE 48 288 16 288
WIRE 3008 288 3008 256
WIRE 128 384 16 384
WIRE 256 384 208 384
WIRE 384 384 320 384
WIRE 416 384 384 384
WIRE 16 480 16 384
WIRE 128 480 16 480
WIRE 240 480 208 480
WIRE 384 480 384 384
WIRE 384 480 320 480
WIRE 16 576 16 480
WIRE 144 576 16 576
WIRE 176 576 144 576
WIRE 288 576 256 576
WIRE 384 576 352 576
WIRE 416 576 384 576
WIRE 688 576 656 576
WIRE 800 576 768 576
WIRE 832 576 800 576
WIRE 992 576 912 576
WIRE 1024 576 992 576
WIRE 1136 576 1104 576
WIRE 1168 576 1136 576
WIRE 1280 576 1248 576
WIRE 1376 576 1344 576
WIRE 1424 576 1376 576
WIRE 1648 576 1552 576
WIRE 1840 576 1648 576
WIRE 1872 576 1840 576
WIRE 2416 576 2176 576
WIRE 1552 608 1552 576
WIRE 2480 608 2448 608
WIRE 2448 624 2448 608
WIRE 2480 624 2448 624
WIRE 2576 624 2544 624
WIRE 2448 640 2448 624
WIRE 2480 640 2448 640
WIRE 2448 656 2448 640
WIRE 2480 656 2448 656
WIRE 144 672 144 576
WIRE 288 672 144 672
WIRE 384 672 384 576
WIRE 384 672 352 672
WIRE 896 672 864 672
WIRE 1840 672 1840 576
WIRE 1872 672 1840 672
WIRE 2064 672 2032 672
WIRE 2176 672 2176 576
WIRE 2208 672 2176 672
WIRE 2480 672 2368 672
WIRE 1872 720 1840 720
WIRE 2064 720 2048 720
WIRE 2208 720 2176 720
WIRE 2416 720 2416 576
WIRE 2416 720 2384 720
WIRE 2480 720 2416 720
WIRE 864 736 864 672
WIRE 2448 736 2448 656
WIRE 2480 736 2448 736
WIRE 2576 736 2544 736
WIRE 800 752 800 576
WIRE 832 752 800 752
WIRE 2448 752 2448 736
WIRE 2480 752 2448 752
WIRE 992 768 992 576
WIRE 992 768 896 768
WIRE 1024 768 992 768
WIRE 2448 768 2448 752
WIRE 2480 768 2448 768
WIRE 688 784 656 784
WIRE 800 784 768 784
WIRE 832 784 800 784
WIRE 2448 784 2448 768
WIRE 2480 784 2448 784
WIRE 240 800 208 800
WIRE 1232 800 1200 800
WIRE 1552 816 1552 688
WIRE 1696 816 1552 816
WIRE 1728 816 1696 816
WIRE 1696 832 1696 816
WIRE 1728 832 1696 832
WIRE 1952 832 1952 768
WIRE 1952 832 1792 832
WIRE 2576 832 1952 832
WIRE 1696 848 1696 832
WIRE 1728 848 1696 848
WIRE 1200 864 1200 800
WIRE 1696 864 1696 848
WIRE 1728 864 1696 864
WIRE 2576 864 1792 864
WIRE 208 880 208 800
WIRE 1136 880 1136 576
WIRE 1168 880 1136 880
WIRE 1552 880 1552 816
WIRE 1696 880 1696 864
WIRE 1728 880 1696 880
WIRE 144 896 144 672
WIRE 176 896 144 896
WIRE 1376 896 1376 576
WIRE 1376 896 1232 896
WIRE 1504 896 1376 896
WIRE 1840 896 1840 720
WIRE 2176 896 2176 720
WIRE 2176 896 1840 896
WIRE 2448 896 2448 784
WIRE 2448 896 2176 896
WIRE 2576 896 2448 896
WIRE 384 912 384 672
WIRE 384 912 240 912
WIRE 992 912 384 912
WIRE 1136 912 1072 912
WIRE 1168 912 1136 912
WIRE 176 928 144 928
WIRE 1504 944 1376 944
WIRE 1376 992 1376 944
WIRE 1424 992 1376 992
WIRE 144 1056 144 928
WIRE 176 1056 144 1056
WIRE 384 1056 256 1056
WIRE 560 1056 528 1056
WIRE 16 1088 16 576
WIRE 144 1088 144 1056
WIRE 384 1088 384 1056
WIRE 528 1088 528 1056
WIRE 800 1088 800 784
WIRE 1136 1088 1136 912
WIRE 1376 1088 1376 992
WIRE 1648 1088 1648 576
WIRE 1840 1088 1840 896
WIRE 16 1200 16 1168
WIRE 144 1200 144 1168
WIRE 144 1200 16 1200
WIRE 384 1200 384 1168
WIRE 384 1200 144 1200
WIRE 528 1200 528 1168
WIRE 528 1200 384 1200
WIRE 656 1200 656 784
WIRE 656 1200 528 1200
WIRE 800 1200 800 1168
WIRE 800 1200 656 1200
WIRE 1136 1200 1136 1168
WIRE 1136 1200 800 1200
WIRE 1376 1200 1376 1168
WIRE 1376 1200 1136 1200
WIRE 1552 1200 1552 960
WIRE 1552 1200 1376 1200
WIRE 1648 1200 1648 1168
WIRE 1648 1200 1552 1200
WIRE 1840 1200 1840 1168
WIRE 1840 1200 1648 1200
WIRE 16 1232 16 1200
FLAG 400 144 DRVB
IOPIN 400 144 In
FLAG 832 144 DRVC
IOPIN 832 144 In
FLAG 2288 624 0
FLAG 2288 768 0
FLAG 2576 624 DRVB
IOPIN 2576 624 Out
FLAG 2576 736 DRVC
IOPIN 2576 736 Out
FLAG 3008 288 0
FLAG 208 -80 0
FLAG 128 -80 DRVA
IOPIN 128 -80 In
FLAG 48 288 ISNS
IOPIN 48 288 Out
FLAG 1664 -224 HTFA
IOPIN 1664 -224 Out
FLAG 2336 -160 HEATA
IOPIN 2336 -160 Out
FLAG 2064 672 DRVA
IOPIN 2064 672 Out
FLAG 1952 624 0
FLAG 1872 576 VDD
IOPIN 1872 576 Out
FLAG 1872 768 0
FLAG 2576 864 PWM
IOPIN 2576 864 Out
FLAG 2576 896 CLK
IOPIN 2576 896 Out
FLAG 1424 992 RAMP
IOPIN 1424 992 Out
FLAG 1424 576 VCEA
IOPIN 1424 576 Out
FLAG 656 576 ISNS
IOPIN 656 576 In
FLAG 2496 672 0
FLAG 2496 784 0
FLAG 416 576 VVEA
IOPIN 416 576 Out
FLAG 416 384 HTFA
IOPIN 416 384 In
FLAG 16 1232 0
FLAG 2064 720 DNVA
IOPIN 2064 720 Out
FLAG 3040 -160 HEATB
IOPIN 3040 -160 Out
FLAG 1744 816 0
FLAG 2576 832 CLR
IOPIN 2576 832 Out
FLAG 1664 -160 VHTA
IOPIN 1664 -160 Out
FLAG 1024 768 VCDA
IOPIN 1024 768 Out
FLAG 1200 928 0
FLAG 864 800 0
FLAG 208 944 0
FLAG 240 800 VCC
IOPIN 240 800 Out
FLAG 896 672 VCC
IOPIN 896 672 Out
FLAG 1232 800 VCC
IOPIN 1232 800 Out
FLAG 560 1056 VCC
IOPIN 560 1056 Out
SYMBOL ind2 544 -64 R0
WINDOW 0 -65 45 Left 2
WINDOW 3 -65 69 Left 2
SYMATTR InstName LPA
SYMATTR Value 317µ
SYMATTR Type ind
SYMATTR SpiceLine Rser=10m
SYMBOL ind2 992 48 R180
WINDOW 0 -64 74 Left 2
WINDOW 3 -81 41 Left 2
SYMATTR InstName LSA
SYMATTR Value 388m
SYMATTR Type ind
SYMATTR SpiceLine Rser=1R
SYMBOL diode 1056 -144 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName DRA
SYMATTR Value DID
SYMBOL diode 1120 -96 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName DRB
SYMATTR Value DID
SYMBOL diode 1120 48 R90
SYMATTR InstName DRC
SYMATTR Value DID
SYMBOL diode 1056 160 R270
SYMATTR InstName DRD
SYMATTR Value DID
SYMBOL sw 480 224 M180
WINDOW 0 -78 122 Left 2
WINDOW 3 -77 97 Left 2
SYMATTR InstName SPPA
SYMATTR Value MSW
SYMBOL sw 752 224 R180
WINDOW 0 -92 126 Left 2
WINDOW 3 -88 101 Left 2
SYMATTR InstName SPPB
SYMATTR Value MSW
SYMBOL diode 576 192 R180
WINDOW 0 29 89 Left 2
WINDOW 3 34 66 Left 2
SYMATTR InstName DBA
SYMATTR Value DID
SYMBOL diode 656 192 M180
WINDOW 0 21 92 Left 2
WINDOW 3 22 68 Left 2
SYMATTR InstName DBB
SYMATTR Value DID
SYMBOL voltage 16 32 R0
WINDOW 0 36 43 Left 2
WINDOW 3 38 69 Left 2
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName VBUS
SYMATTR Value 19V
SYMBOL Digital\\dflop 2288 624 R0
WINDOW 0 48 -19 Left 2
SYMATTR InstName A2
SYMATTR SpiceLine Vhigh=15V Vlow=0V Td=10n
SYMBOL ind2 688 48 R180
WINDOW 0 -58 66 Left 2
WINDOW 3 -69 43 Left 2
SYMATTR InstName LPB
SYMATTR Value 317µ
SYMATTR Type ind
SYMBOL diode 272 192 R180
WINDOW 0 43 45 Left 2
WINDOW 3 73 20 Left 2
SYMATTR InstName DCATCH
SYMATTR Value DID
SYMBOL ind 336 -144 R270
WINDOW 0 32 56 VTop 2
WINDOW 3 5 56 VBottom 2
SYMATTR InstName LBUCK
SYMATTR Value 50µ
SYMBOL sw 240 -160 M270
WINDOW 0 74 96 VLeft 2
WINDOW 3 49 85 VLeft 2
SYMATTR InstName SBUCK
SYMATTR Value MSW
SYMBOL res 416 240 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName RSNS
SYMATTR Value 25m
SYMBOL cap 1216 -48 R0
WINDOW 0 40 22 Left 2
WINDOW 3 43 46 Left 2
WINDOW 123 42 74 Left 2
SYMATTR InstName CFA1
SYMATTR Value 10µ
SYMATTR Value2 IC=420
SYMBOL res 1216 128 R0
WINDOW 0 39 45 Left 2
WINDOW 3 40 71 Left 2
SYMATTR InstName RDA1
SYMATTR Value 1R
SYMBOL ind2 1792 48 R180
WINDOW 3 -76 49 Left 2
SYMATTR InstName LSB
SYMATTR Value 355µ
SYMATTR Type ind
SYMBOL diode 1856 -144 R270
SYMATTR InstName DRE
SYMATTR Value DID
SYMBOL diode 1920 -96 R90
SYMATTR InstName DRF
SYMATTR Value DID
SYMBOL diode 1920 48 R90
SYMATTR InstName DRG
SYMATTR Value DID
SYMBOL diode 1856 160 R270
SYMATTR InstName DRH
SYMATTR Value DID
SYMBOL cap 2016 -48 R0
WINDOW 123 48 72 Left 2
SYMATTR InstName CFB1
SYMATTR Value 1000µ
SYMATTR Value2 IC=12.6
SYMBOL res 2016 128 R0
SYMATTR InstName RESRB
SYMATTR Value 10m
SYMBOL voltage 1376 1072 R0
WINDOW 0 38 57 Left 2
WINDOW 3 24 96 Invisible 2
SYMATTR InstName VRMP
SYMATTR Value PULSE(0.5 3.4 0 9.5u 500n 0 10u)
SYMBOL voltage 1840 1072 R0
WINDOW 0 36 53 Left 2
SYMATTR InstName VCLK
SYMATTR Value PULSE(0 15 10u 1n 1n 500n 10u)
SYMBOL sw 1552 864 R0
WINDOW 0 8 -12 Left 2
WINDOW 3 7 8 Left 2
SYMATTR InstName PWM
SYMATTR Value CMP
SYMBOL res 1536 592 R0
WINDOW 0 37 44 Left 2
WINDOW 3 38 71 Left 2
SYMATTR InstName RDD
SYMATTR Value 1K
SYMBOL voltage 1648 1072 R0
WINDOW 0 37 41 Left 2
WINDOW 3 36 70 Left 2
SYMATTR InstName VDD
SYMATTR Value 15V
SYMBOL Digital\\dflop 1952 624 R0
SYMATTR InstName A1
SYMBOL res 1264 560 R90
SYMATTR InstName R15
SYMATTR Value 30K
SYMBOL res 1120 560 R90
SYMATTR InstName R12
SYMATTR Value 10K
SYMBOL voltage 384 1072 R0
WINDOW 0 46 47 Left 2
WINDOW 3 49 74 Left 2
SYMATTR InstName VREF
SYMATTR Value 5V
SYMBOL res 272 560 R90
SYMATTR InstName R5
SYMATTR Value 330K
SYMBOL cap 352 560 R90
SYMATTR InstName C2
SYMATTR Value 82p
SYMBOL cap 352 656 R90
SYMATTR InstName C3
SYMATTR Value 22p
SYMBOL res 0 1072 R0
WINDOW 0 40 45 Left 2
WINDOW 3 38 70 Left 2
SYMATTR InstName R4
SYMATTR Value 2K155
SYMBOL res 224 368 R90
SYMATTR InstName R1
SYMATTR Value 18K
SYMBOL cap 320 368 R90
WINDOW 0 7 61 VBottom 2
WINDOW 3 -17 -6 VTop 2
WINDOW 123 38 34 VTop 2
SYMATTR InstName C1
SYMATTR Value 3n3
SYMBOL Digital\\or 2512 576 R0
SYMATTR InstName A3
SYMBOL Digital\\or 2512 688 R0
SYMATTR InstName A4
SYMBOL res 2288 128 R0
WINDOW 0 42 44 Left 2
WINDOW 3 38 66 Left 2
SYMATTR InstName RLB
SYMATTR Value 16R8
SYMBOL res 928 560 R90
SYMATTR InstName R11
SYMATTR Value 22K
SYMBOL res 784 768 R90
SYMATTR InstName R9
SYMATTR Value 1K6
SYMBOL res 784 560 R90
SYMATTR InstName R8
SYMATTR Value 1K6
SYMBOL res 816 1184 R180
WINDOW 0 47 66 Left 2
WINDOW 3 48 45 Left 2
SYMATTR InstName R10
SYMATTR Value 22K
SYMBOL Digital\\or 1760 912 M180
SYMATTR InstName A5
SYMBOL ind2 2496 48 R180
WINDOW 3 -75 50 Left 2
SYMATTR InstName LSC
SYMATTR Value 355µ
SYMATTR Type ind
SYMBOL diode 2560 -144 R270
SYMATTR InstName DRI
SYMATTR Value DID
SYMBOL diode 2624 -96 R90
SYMATTR InstName DRJ
SYMATTR Value DID
SYMBOL diode 2624 48 R90
SYMATTR InstName DRK
SYMATTR Value DID
SYMBOL diode 2560 160 R270
SYMATTR InstName DRL
SYMATTR Value DID
SYMBOL cap 2720 -48 R0
WINDOW 123 44 72 Left 2
SYMATTR InstName CFC1
SYMATTR Value 1000µ
SYMBOL res 2720 128 R0
SYMATTR InstName RESRC
SYMATTR Value 10m
SYMBOL res 2992 128 R0
WINDOW 0 40 46 Left 2
WINDOW 3 40 72 Left 2
SYMATTR InstName RLC
SYMATTR Value 16R8
SYMBOL Opamps\\LT1677 208 848 R0
WINDOW 0 19 2 Left 2
WINDOW 3 22 28 Left 2
SYMATTR InstName VEA
SYMBOL Opamps\\LT1677 864 704 R0
WINDOW 0 18 4 Left 2
WINDOW 3 20 28 Left 2
SYMATTR InstName CDA
SYMBOL Opamps\\LT1677 1200 832 R0
WINDOW 0 16 4 Left 2
WINDOW 3 16 29 Left 2
SYMATTR InstName CEA
SYMBOL voltage 528 1072 R0
SYMATTR InstName VCC
SYMATTR Value 3.5V
SYMBOL res 272 1040 R90
SYMATTR InstName R6
SYMATTR Value 22K
SYMBOL res 160 1184 R180
WINDOW 0 -68 70 Left 2
WINDOW 3 -80 44 Left 2
SYMATTR InstName R7
SYMATTR Value 22K
SYMBOL res 1088 896 R90
SYMATTR InstName R13
SYMATTR Value 22K
SYMBOL res 1152 1184 R180
WINDOW 0 -59 71 Left 2
WINDOW 3 -59 45 Left 2
SYMATTR InstName R14
SYMATTR Value 22K
SYMBOL res 224 464 R90
SYMATTR InstName R3
SYMATTR Value 180K
SYMBOL res 336 464 R90
SYMATTR InstName R2
SYMATTR Value 180K
SYMBOL current 1632 144 R0
WINDOW 3 24 80 Invisible 2
SYMATTR Value PULSE(50mA 50mA 0 100n 100n 1m 2m)
SYMATTR InstName I1
SYMBOL cap 1344 560 R90
SYMATTR InstName C4
SYMATTR Value 390p
SYMBOL ind 2048 -144 R270
SYMATTR InstName LFB
SYMATTR Value 100µ
SYMBOL ind 2752 -144 R270
SYMATTR InstName LFC
SYMATTR Value 100µ
SYMBOL cap 2160 -32 R0
WINDOW 0 43 8 Left 2
WINDOW 3 45 30 Left 2
WINDOW 123 45 55 Left 2
SYMATTR InstName CFB2
SYMATTR Value 330n
SYMBOL cap 2864 -32 R0
SYMATTR InstName CFC2
SYMATTR Value 330n
SYMBOL ind 1248 -144 R270
SYMATTR InstName LFA
SYMATTR Value 100µ
SYMBOL cap 1360 -32 R0
WINDOW 0 41 6 Left 2
WINDOW 3 43 32 Left 2
WINDOW 123 44 58 Left 2
SYMATTR InstName CFA2
SYMATTR Value 330n
SYMBOL cap 1488 -32 R0
SYMATTR InstName CFA3
SYMATTR Value 1µ
SYMBOL res 1488 128 R0
SYMATTR InstName RDA2
SYMATTR Value 18R
TEXT 1536 336 Left 2 !K1 LPA LPB LSA LSB LSC 1
TEXT 1528 408 Left 2 !.MODEL DID D(Ron=10m Roff=1E7)
TEXT 1528 360 Left 2 !.MODEL MSW SW(Ron=10m Roff=1E7 Vt=7V5)
TEXT 1528 456 Left 2 !.LIB OPAMP.SUB
TEXT 1528 480 Left 2 !.tran 0 10m 5m uic
TEXT 1528 432 Left 2 !.MODEL ZID D(Ron=10m Roff=1E9 VRev=5V)
TEXT 1528 384 Left 2 !.MODEL CMP SW(Ron=10m Roff=1E7 Vt=0V)
LINE Normal 928 32 928 -48 2
LINE Normal 944 32 944 -48 2
LINE Normal 608 48 608 -48 2
LINE Normal 624 48 624 -48 2
LINE Normal 1728 32 1728 -48 2
LINE Normal 1744 32 1744 -48 2
LINE Normal 2432 32 2432 -48 2
LINE Normal 2448 32 2448 -48 2
  • Screenshot at 2017-12-12 16:17:16.png
  • Screenshot at 2017-12-12 15:50:10.png
  • Screenshot at 2017-12-12 16:01:42.png
  • Screenshot at 2017-12-12 16:14:53.png
I haven't thanked you yet MorbidFractal, so thank you.
In the end I took the easy way out. I ordered a 12V @ 5A Meanwell smps and a 12 to 200-450V converter from eBay. Together they should be up to the task. The high voltage converter easily does 20mA at 440V. That's all I need. I probably need some more filtering in the B+ supply to filter out high frequency content. I was thinking about adding a LC filter, something like 330uH and 4u7. Does that seem right?
The experiment did not work as good as intended.
Firstly the dc/dc converter for the HV was not isolated. There seems to be a resistive path form the - at the secondary side to the - at the primary side. My guess: a simple adjustable resistive divider. Hence lifting the 12V supply to 70/80V did not work as expected (read: not at all). With cathodes of 12ax7 cathode followers at 200V I can't get away with a normal ground connected faux centre tap on the heaters.
What did work, was supplying the heaters with a separate 12V smps and lifting just that one and use the other 12V smps to power the DC/DC converter. I think this is far from ideal.
Secondly there was a lot of switching garbage on the HV that I just could not get rid of. The supplies were rather far away from the test preamp board I made, not likely to be EMF products being the culprit. The only way to tame the hum generated by the DC/DC converter was adding a RC filter behind it. Still to much garbage on the PSU to sound clean. There was a constant faint 250 Hz tone hearable.
What makes it difficult to address the problems is that the DC/DC converter is a black box. No schematic, no name on the control IC (other than some Chinese signs), no data sheet for the MOSFETS. Construction seems good but engineering is a bit sub par. No snubber over the single output diode, just one C filter at the output, no input filtering that I could see. I guess I could say not up to the task of supplying B+ to a highly sensitive guitar preamp.
So, back at square one!
I'd still like to go the route of an smps. Size does matter as the preamp must fit in a 1U rack enclosure (40mm internal height). I'm open to the option of a transformer too as long as it does a rectified 430 and 12.6 V.
Then I still suggest you use one of these. It is isolated and so shouldn't mind it's 12V being referenced to 80V. Use the square wave 220V AC output and a voltage doubler to get 440VDC. You must use ultrafast diodes such as HER108 or UF4007.
I use one for a four tube 6SN7 based Williamson front end, another for an Aikido 6N3P/6N6P headphone amp. No measurable noise with my scope, either. DC-AC Converter 12V to 110V 200V 220V 280V 150W Inverter Boost Board Transformer | eBay
