LM1875 layout
Could any1 help diy noob, would this pcb cover basic needs of lm1875 to work properly?
I like this board because it is speaker protection + power filter + both channels on same pcb.
I like that it has center ground point between main capacitors so i can connect all to that center ground.
I see it has c104 close to pins 3 and 5 to prevent oscilation + it has elect. caps near too
Zobel network is there so it is another +.
If any1 could spot some bad spots it would be great to point that out.
Sorry for my english and thanks.
In this pdf on that picture i can see that in one point signal return is conected to point between capacitors. Ofc i cant reproduce all from that pdf because i cant make my own pcb and I dont want to make amp point to point way.
That's standard for the negative terminal these days.
Has been for 30+ years.
They have a roll of shrink tube with a "- - - - -" stripe to mark the negative leg. Often with a fat stripe so a wrong-way cap will stand-out on quick inspection of board.
I do not know why draftsmen mark "+" and cap makers mark "-". But we should be able to figure it out.
