Not fair, I know you have them suspended on those $5,000/pc. myrtle blocks.
good price
![yikes :yikes: :yikes:](https://files.diyaudio.com/forums/images/smilies/yikes.gif)
/sarcasm
I normally stay out of these sort of discussions but I feel the skeptics here have missed a possibility.
Onnes' research into unexpected deviations from normal conductivity lead to his Nobel Prize.
Josephson predicted even more obscure and tiny deviations from expected conductivity and scored a Nobel too.
Now any unknown physical effect that is sufficient to product audible effects but has somehow been unnoticed in over a hundred years of research into conductivity must be a Nobel for sure!
So if any of the proponents of cable directivity would like to provide some evidence that meets the usual standards of science then I will be happy to finish off the research and split the $1,000,000 prize money.
What the hell, I always wanted a Nobel, you can have ALL the money.
It's an easy $Million if what you say is true, I just need a few clues for a research proposal.
Best wishes
David
That's why I've been reminding those proponents of cable directionality that a Nobel waits for the validation of their claims and to mind the effects of room temperature and bull materials on the ensemble behavior. ;-)
optical
The point is that it is perfectly possible to alter the behavior of systems at a distance, the question is why.
Photons now too, certainly enough here for two Nobels.
Hello David.
Ok, I have a wide ranging and interesting bunch of observations that do not completely accord with conventional theory as I and others understand it, and not all of which I am willing to divulge to the 'pitchfork wielding villagers' present here.
Actually other than your Behringer mods you haven't divluged a single thing in a manner that would allow a repeatable experiment. Just anecdotes about steered demos.
Don't forget Clever Hans!
independendently reproducible evidence.
Difficult when no measurement of claimed effects can be made (apparently).
Several short pages actually, starting at page 87:Bill Whitlock did a page on why the shield needs to be connected at the driven end rather than at the receive end. But then, interference is rather situation specific.
http://centralindianaaes.files.wordpress.com/2012/09/indy-aes-2012-seminar-w-notes-v1-0.pdf
I thought you meant with pseudo balanced. Shield of a balanced line should be connected at both ends
Hans Polak made a good point for OEO (one end only) grounding of the screen in his Linear Audio article Pin 1 revisited, adding OEO to an accepted rule, with comments from Bill Whitlock.
Jan
You mean something like this "ground box"?Hans Polak made a good point for OEO (one end only) grounding ...
I forgot. This is the snake oil thread...
Sorry for temporarily going over to facts and data. I'll try to do better next time ;-)
Jan
Wasn't this already covered with the observer effect, with the slit foil photon experiment?
How do I know these aren't alternative facts?Sorry for temporarily going over to facts and data.
No the delayed choice experiment is different, I was talking about an unknown field that interacts with photons (E&M don't).
How do I know these aren't alternative facts?![]()
I actually thought about it long and hard ;-)
You should try that sometimes.
Jan
Two days ago I bought two pairs of Sony ear bud headphones that were on clearance special.
I cracked one pair open and applied the mixture to the magnets and connections of the miniature drivers.
So far, three out of three subjects indicated strong preference for the treated pair in double blind testing.
Dan.
Dan.
- Member Areas
- The Lounge
- Funniest snake oil theories
