Hi Tim,
First of all, thanks for your great work!
I am thinking upgrading my old HifiBerry DAC and getting a AUDIOPHONICS I-Sabre DAC ES9028Q2M, but I can´t find the AUDIOPHONICS ES9028Q2M DAC in I2S audio device list in Moode.
¿Will it work?, ¿or a special driver will be needed?
Thanks.
The I2S list contains Audiophonics ES9028 DAC.
rpi-dac driver is loaded if using Std kernel
i-sabre-dac-es9023-audio,384k driver is loaded if using Adv kernels
-Tim
-Tim
I sent back my faulty 9028 card to audiophonics; and they sent me back a new one which is working very well with moode. it has a higher gpio connector so it is less close to the kali and rpi. I don't know if there is more modifications made.
Kali and wifi are now working well with this great card.
Hello, i had version with higher gpio connector and I had the crackling issues even with PCM decoding, so I think they fixed something else or there was some other issue... so now you dont have any problem, no loud pops and crackling on track start and during song shifting... thanks VitaHi,
yes, for now(72h), no more crackling or strange noises between tracks.
Hi, thanks, I already have sent my DAC back so hope they will provide new one ...yes, for now(72h), no more crackling or strange noises between tracks.
Does Moode on RPi3 support this I2S DAC with ES9028Q2M?
Assembly ES9028Q2M ES9028 I2S DSD Input DAC Decoders Board With Soft Control CPU | eBay
Setup for pizeroaudio Audio DAC HAT
running the latest moodeaudio on RPi0-w, I bought this from amazon : Amazon.com: WITH RCA ! -- Audio DAC HAT Sound Card for Raspberry Pi Zero / A+ / B+ / Raspberry Pi 2 Model B: Computers & Accessories
"HiFIBerry DAC" does not seem to work, any ideas?
thanks,
thanks,
Hi Tim,
I'm a NuBi to all this and giving moode a try in my home made wifi speakers running off rpi3 with a hifi berry amp hat on top. Presently I'm running LMS on my PC as a server and using squeezer to sync my multiple speakers which works great. My problem is when I select internet radio in squeezer it doesn't show anything. What am I'm missing?
Hi @gychang,
What I2S driver does the manufacturer specify for this board?
-Tim
They don’t...
It uses an NXP UDA1334a chip, which works with the generic/Hifiberry setting.
Cheap DAC... <$0.50 in small quantity...
I use a lot of NXP silicon. Great documentation for their microcontrollers but negligible for their DACs.
HelloDoes Moode on RPi3 support this I2S DAC with ES9028Q2M?
"normal" hifiberry-dac driver should works, but seems that these boards has problem with playing 16 bit material...if I were you i will try this one:
ES9038 Q2M DAC DSD Decoder Support IIS DSD 384KHz Coaxial Fiber DOP | eBay
But these are cheap ones so maybe you should count with "some" issuess...
Regards Vita
Hello
Regards Vita
I wondered when this board would get some light...
As Tim has said elsewhere....an MCU on an Ess board that exposes the i2c lines for the hardware volume control and FIR filters would be an interesting workaround.....
DSD64 over coaxial and optical and DSD256 over i2c....
Optical&coaxial input: DSD64 DOP
PCM:44.1KHz,48KHz,88.2KHz,96KHz,
176.4KHz,192KHz,352.8KHz,384KHz
DSD: 2.8 MHz (DSD64) - DoP,native
5.6 MHz (DSD128) - DoP,native
11.2 MHz (DSD256) - native
There is a connector for volume control, One 10K ohm potentiometer can be series connected to adjust volume.
Fix for Hifiberry DAC+ Pro at 352.8 kHz
Hello Tim and Klaus (soundcheck)!
Daniel at Hifiberry has patched the driver for the DAC+ Pro so that 352.8 kHz won't clock at 384 kHz. It appears it has been committed, too:
Fixed a bug when using 352.8kHz sample rate by hifiberry * Pull Request #2231 * raspberrypi/linux * GitHub
Hopefully the kernal update will make it into Moode someday soon
From the snippet of code I saw in the pull request, I don't believe it will break the 384 kHz party for others.
Thanks again,
Richard
Thanks again,
Richard
He hopefully also patched the PCM51xx codec to enable 352.8 once and forever
also with the standard kernels! Perhaps you gonna tell him!
It's a very trivial patch - which is available since quite some time.
Hello
Regards Vita
Vulnerability - WPA2 and RPI
Not sure if Moode adresses this but wants to bring it to Tim's attention. It concerns a crack of the WPA2 encryption. The chance of your system being infiltrated is slim but the following website does advise to install the latest RPI versions.
Main article - PSA: Severe Vulnerability in All Wi-Fi Devices
List of devices affected and updates...
List of Firmware & Driver Updates for KRACK WPA2 Vulnerability
- PC Based
- Moode Audio Player for Raspberry Pi
