I have a pair of Carver Amazings - Silver Edition. Ribbons are 48".
1 of the ribbons has no output whatsoever. I have removed it from the frame and cut the leads at the bottom. Feeding a signal directly to the leads (or where they attach to the small board) gives no results.
Any suggestions will be greatly appreciated.
After so many years the magnets are prone to breaking loose from the frames and the diaphragms are prone to buzzing and shorting out.
A friend on the CarverSite Forum has rebuilt quite a few of those ribbons; which involves a complete tear down and re-gluing all magnets in place (using a special jig) with newer/better adhesives, followed by installing new corrugated polyamide film / AL foil diaphragms.
Be advised though, that the original diaphragms were made from 1-mil polyamide film which is no longer manufactured by any supplier.
My re-builder friend found a supplier to makeup a special batch of 2-mil polyamide film with bonded aluminum conductors. The 2-mil diaphragms roll off the highs a bit lower than the originals (due to the higher mass) and the resistance is a bit lower too, but they still sound great (I've heard them) and are more robust than the originals.
If you're interested, PM me and I'll contact my friend to see if he wants to do it.
Scott,
I just talked to my friend. His current rebuild price is $250 per ribbon + shipping both ways (he lives in NC). I will PM you his name & phone number.
DeltaStar,
I have my friend's permission to PM you his contact info. You may find him reluctant to sell the film alone, however--considering the time, effort and cost to find a supplier willing to fab a one-off batch was so high that he really needs to do the complete rebuilds to recoup that investment.
DeltaStar,
Hi Charlie, find out how much for the 60" one piece ribbon? Thanks
Yes, my friend also rebuilds the 60" Carver ribbons. The price is $300 each plus shipping to and from NC.
Carver 60 inch ribbon.
Hi Charlie , is your buddy still repairing these ribbons, and what is the cost today for a 60 inch ribbon,.
It is true that it is difficult to get the original Kapton film. It was ½mil (12.7 µm), still too thick for the best high frequency reproduction. If you replace it with an even thicker film, it will reduce HF even more.
- Planars & Exotics
- Carver Amazing Ribbon - no output
