Quasimodo results (ONLY)
Block RKD 160/2X15
Cx 10nF
Cs 150nF
Rs 26Ω
[Data supplied by SGK, http://www.diyaudio.com/forums/powe...using-quasimodo-test-jig-126.html#post5206652 post #253]
Hammond 229C40
Cx 10nF
Cs 150nF
Rs 577Ω
[Data supplied by luvdunhill, post #527]
Hammond 160H12
Cx 10nF
Cs 150nF
Rs 11.5Ω
[Data supplied by luvdunhill, post #528]
Nuvotem 120VA, dual 15V secondaries
Cx 10nF
Cs 150nF
Rs 42.5Ω
Nuvotem 80VA, dual 15V secondaries
Cx 10nF
Cs 150nF
Rs 39Ω
Nuvotem 50VA, dual 15V secondaries
Cx 10nF
Cs 150nF
Rs 38.6Ω
[Data supplied by B&W_arthur, post #351]
Triad Magnetics VPT30-5330, dual 15V secondaries
Cx 10nF
Cs 150nF
Rs 22.6Ω
[Data supplied by Mark Johnson, http://www.diyaudio.com/forums/powe...using-quasimodo-test-jig-126.html#post5206652 post #255]
Antek 400VA, 18v
Cx 10nF
Cs 150nF
Rs 18.3Ω
[Data supplied by rickmcinnis, post #978]
R-Core 120VA, dual centre-tapped 18-0-18 secondaries
Cx 10nF
Cs 150nF
Rs 54Ω/54Ω, 69Ω/69Ω
[Data supplied by alexkosha, post #1219]
Edcor #XPWR274 (Torpedo and Torpedo III), 200V B+ and 6.3V filament
B+ Cx: 6.8nF
B+ Cs: 68nF
B+ Rs: 760Ω
filament Cx: 10nF
filament Cs: 150nF
filament Rs: 12Ω
Bottlehead PT-10 (SEX), 160V B+ and 6.3V filament
filament Cx: 10nF
filament Cs: 100nF
filament Rs: 9Ω
B+ Cx: 10nF
B+ Cs: 100nF
B+ Rs: 400Ω
Torroidy 300VA, 240V primary, dual 36V secondaries
Cx: 10nF
Cs: 150nF
Rs: 12Ω / 14Ω
Torroidy 500VA, 240V primary, dual 18V secondaries
Cx: 10nF
Cs: 150nF
Rs: 7Ω / 7Ω
Theoretically it would be possible to write a software "bot" which uses the data contained within these posts, to calculate the transformer secondary's effective leakage inductance. Cx makes it both impossible, and irrelevant, to calculate the secondary's effective self capacitance.
Antek 400VA, 18v
Cx 10nF
Cs 150nF
Rs 18.3Ω
Jeff,
I've tested two Antek AS-4218, and one AN-4218 using the same Cx=10nf, and Cs=150nf. I'm coming up with a way different Rs values than you have posted, but consistent between the three transformers tested. How confident can we be that the values posted in this thread are accurate? I get what you're trying to do here, but I'm encouraging others to build their own Quasimodo/Cheapomodo and verify for themselves.
Posted 08 December 2018 HERE
_
attachment.php
_
Talema 2x115V, 2x7V, 2x12,5VA
Primaries in series for 230V operation and shorted (for snubbing)
Secondaries in parallel
Cs=150nF, Cx=10nF -> fosc ~ 625kHz(!)
Snubbing this small print torodial transformer I get values for Rs ~ 12Ohm.
Are such low values for Rs reasonable?
Audiomusica, since you doubt your experimental results from No-Math Quasimodo, you have no other choice than to use math for verification.
Your numerical values of fosc (6.25E+5) and Cx (1.0E-8) indicate that the secondary self inductance L is about (6.5E-6) Henrys. We calculate L using the LC resonance equation.
The LC resonance equation: 2 * Pi * fosc = 1 / sqrt(L * C)​
Plugging this value for L into equation (A.11) of the Quasimodo design note, we find
R < 12.7 ohms​
Which seems to be in broad agreement with your experimental results. You were wrong to doubt them.
