Tweeter excursion
Right, I see Xmax on some datasheets but I don't know enough about speaker specifications to know if that's frequency-independent.
I would assume mounting on a flat baffle. The Revelator referenced above shows linear excursion of 0.4 mm, which implies peak-to-peak displacement of 0.8 mm. Could I actually get that much excursion at 20 kHz without burning the thing up? I'm not looking for a specific dB so much as I am trying to create high frequency displacement (like a linear motor).
OK, thanks. Let's take a single example: the Revelator referenced earlier. How would I go about estimating its continuous allowable excursion for a 20 kHz input signal? Would this involve specifying maximum current and then calculating the mechanical response to that current?
The current is what you need to worry about. As the heats builds up, the wire enamel starts cooking until it burns up and the coil shorts. I don't have the formula at hands for estimating excursion at a desired frequency.
I'm sorry scottjoplin, I don't know where you got that idea. Flat frequency response is a decription of sound output, not diaphragm travel. Lower frequencies require more travel of the diaphragm(with same area), hence the trouble crossing smaller(or those with less travel) drivers as low as larger ones.
Hi jimmyjazz,
Attached is a simulation of the ScanSpeak D2905/990000. Xmax would allow for an SPL of 150 dB at 20 kHz, but power handling actually limits the output to 104 dB. 🙂
